hey guys ..
few weeks ago i asked for some help and got some good response from some ppl here. just wanted to show you guys my results..
so the set up is rather simple..
fuel :am using a aermotive stealth pump with some dw800cc injectors
ignition: stock
engine: arp head bolts , wiseco piston stock compression,extended sump and harden oil pump gears and stock everything else..
extra: am also using a aem water injection kit..actually just using filtered rain water to aid our crappy 91 ron fuel ...
management : haltech plug and play
tuned by me :)
15 psi :336trq & 414whp
21 psi :409trq & 499whp
from the dyno graph i thought this would been lagy ..but i was so wrong ....car pulls and spools just as good as my old precision 6262 bb .makes more power at same boost. at 11 psi with the old 6262 i was making around 340hp & with the 8375 11psi car made around 370hp both without water injection
honestly very impressed for a turbo i paid 580us for compared to the 6262 which cost 1200us..
and all of this was done with a single scroll 8375 and a ebay single scroll $140us manifold..... may be i got lucky with manifold but its just as strong as the one i paid 400us for before.have put countless abuse on it and no cracks yet.
dyno graph and vid
https://www.youtube.com/watch?v=VfhW7fvX-Bg
https://www.sau.com.au/forums/topic/452309-rb26-borgwarner-8375/
No doubt they are an awesome turbo for the price, I would love to see a back to back against the precision. These things spool like a beast and there's plenty more in that turbo for you if you put the money in the right gear.
I've been running mine with the full race twin scroll manifold and made 560rw hp on ethenol with a 2.6. Made 500rwhp at 5500rpm
I've since upgraded the cams and valve train, cleaned up the head, raised compression, stroked to a 2.9 and ceramic coated the exhaust side .. Results should be up within the month
Old graph.. Rubbish photo but its 98 premium vs E85
Note the car made no more power past 50/50 ethenol/98
yep they do spool super fast for journal bearing turbos..... i was really worried when i first compared it to a physical size of a 6262 .
as you can see in the vid the moto sits in a s15 silvia which is super light ...the weight difference of a r33 at 3400lbs and the s15 2700lbs makes this car feels like its almost at 650hp...
with some cams and cam gears i should be able to get power in a tad quicker and make a higher peak hp...
looking forward to seeing your updated build results...
yep... but the results with the 6262 would not be applicable to compare because it was done with out water injection ..so the timing when tuning was alot different .but the 6262 did make 415whp at 20 psi where as the 8375 made 499hp at the same boost... but the 6262 was only running on a .63 housing which would make high hp numbers on such a big moto difficult .
i had read some where a guy changed out his .82 ar 6262 for a .63 and the results were minimal difference on his rb26..but i cant confirm that........i know on a 2.0 honda moto moving from .63 to .82 makes no difference ..
only results i have with both turbo is at 11psi without water spraying either ways and the 8375 did make more power then....
Ok thanks mate, would be good to see some more results on this turbo going around.. This night spark a bit more interest
Here is my thread on my results if you are interested
http://www.sau.com.au/forums/topic/414766-gtr-joeys-r32-gtr-e-flex-twinscroll-8375-results/
hey.. i used a .88ar back end because i was worried about lag as the turbo was non bb..
your dyno graph is a lil unfair comparison as the bigger ar back ends has 5psi difference .it may not look like much but once these turbo begin to spool the move from 7psi to 21psi in a heart beat... that may contribute to more power lower in the power band..
the twin scroll will help with spool up when combined with a twin manifold..
what moto are these graph from?
  • 9 months later...
Here is my graph on a 6262 by with .84 TS setup and 93 octane gas
611 at 19 psi
550 at 15 psi
I think if I had 9:1 Cr pistons my torque would've been a lot higher
I'm using JE 8:3:1 CR pistons and Tomei 264 cams.
EC990DBB-75E3-4453-89C1-EC9B0C5E4339_zps
Edited by silvianc
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
