So im rebuilding my motor and have done multiple searches to no avail.
I'm trying to track down part numbers for over sized JE Pistons for my neo motor, but can't find them anywhere.
I'm sure people have rebuilt 25s with JE before. Am i wrong?
Does anyone know the part number or someone who does?
https://www.sau.com.au/forums/topic/452349-je-pistons-for-neo-rb25det/
Shouldn't need part numbers - just tell your supplier what you want and they should be able to procure. They may not be in stock anywhere and have to be made to order.
Having said that I haven't seen JE pistons mentioned in a build lately.
Just something to note. Nitto forgies are manufactured by JE. The difference in the piston from Nitto to JE was 1cc in the dome but about $150 difference off the shelf.
HiOctane sold them to me for $1200 I think. maybe $1300
yen the machines I gave my block to said he could get JE cheaper than CP.
Knowing JE is a good brand I agreed, but I also like to do my own research and can't find them anywhere.
I specified multiple times that it is a NEO motor and has different compression ratios, so just hoping he orders the right pistons.
To be honest its hard to find JE for non NEO motors, even the JE website only lists RB26 pistons....
I know of a 3.4L RB26/30 using 87mm JEs and making 800wHP.
they are good.
Also if you're concerned with compression your builder should CC the head and do the calculations prior to even ordering the pistons or a headgasket. you can always ask them; if you're spending that kind of money there don't hesitate to ask as many questions as you need!
yeh but I dont want the stuff around. Much easier to just get the correct piston and comp. Considering it will be much cheaper too. Turns out the the machinist now got a set of ross pistons anyway.
By doing what was suggested in the post above yours that's how you actually get the correct piston.
yes but i would still rather start off as close to ball park figure as possible with neo specific pistons. This isnt some nuts build, just a freshen up so the less time and money i can sink into it the better.
So I received my ross pistons today to find that they do not have the valve cut outs like the standard ones do.
Anyone have a pic of other after market pistons for neo motor?
Have I been given the wrong pistons?
Part number is 6mkry9603-0.50
Edited by camoo
so basically the compression height is different, the ross pistons are taller from the center of the gudgeon pin, so im guessing that the pistons are for a non neo rb25det.
The stroke on a neo or r33 rb25 are the same (71.7mm) as to the deck height of the blocks so why would the compression height be different? The combustion chamber is 10.5cc,s smaller on Neo. Below rb forged piston to suit neo head
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
