I put these pictures in the tas section because that's were I'm form but is pretty dead in the tas section. so here's my my block its a r31 series 2 block my engine builder machined my block and fitted rb26 oil squirters out if my old motor in to the rb30 . We did a few tests on a A8 block that was stuffed before going ahead . Im pretty happy with how it turned out :)post-134876-1420446965889_thumb.jpgpost-134876-1420446999866_thumb.jpg
  • Like 2
https://www.sau.com.au/forums/topic/452355-oil-squirters/
Cheers! I'd say it's going to get a fairly hard time I'm not one for mechanical sympathy, but spending so much on the motor this time around I reckon I'll use my head instead stead of my right foot haha
  • Like 1
https://www.sau.com.au/forums/topic/452355-oil-squirters/#findComment-7455462
I avoided it as the blocks a bit thinner than the RB26 ones there.
I ceramic coated the pistons and used Nitto rods with the built in oiling squirter holes.
And a handfull of other oiling mods to keep the oil down low like crack scraper, 26 windage trays on the 30 girdle etc....
https://www.sau.com.au/forums/topic/452355-oil-squirters/#findComment-7455572
There was talk about drilling a little hole on each side of the under side of the piston for the oil to cool down the tops of the piston the same as a 26 piston, he was also talking about drilling a tiny hole throw my h beam rod so they have bore squirters, but he wasn't to sure if it would change the strenght of the rod.
https://www.sau.com.au/forums/topic/452355-oil-squirters/#findComment-7455729
My Builder said if the bottom end lets go or breaks he will supply a new bottom end for me because he wanted to try these modifications to see how they go, he's also my dads good mate so I'm getting it done for near nothing , so I thought I might aswell go all out on it then, yeah it's also getting the crank scraper and windage tray of the 26 aswell :) I didn't no nitto made the oil squirters in the rods, but I had a set of precision Rods so that's why we used them
https://www.sau.com.au/forums/topic/452355-oil-squirters/#findComment-7455742
I buy them in bulk from the states, i am about to place a order on another batch end of this month.
You will need to adjust the fitment to your crank and rods, you need 1mm minimum space from the crank and rods to the plate and a bit extra to the thrust direction of the crank.
Took me a few evenings of grinding to shape to find what worked best for my application, the picture above is new as they arrive before shaping to fit.
https://www.sau.com.au/forums/topic/452355-oil-squirters/#findComment-7458199
do you have pics?
Wanting to do this, but engine machinist is saying it won't fit/work.
Would love to show pics saying otherwise.
https://www.sau.com.au/forums/topic/452355-oil-squirters/#findComment-7463035
Ive kept my build private and only shared it with 1 person here to help them out with their 3.2L stroker.
Here are some of the oiling mods....
Glyptal paint to aid oil drainback in a deburred block, note the annular grooves like in a RB26 block to provide extra oil and use RB26 race series bearings in a RB30 block.
Drilled out all the oil feeds, you can see the tip of the drill bit going into the main feed channel.
Drilled out the oil drains to 10mm, this will require opening up the head gasket oil drain points also.
There are lots of other little things that can be done to assist oiling and block strength such as Cryo treating the block, partial grout filling etc......
https://www.sau.com.au/forums/topic/452355-oil-squirters/#findComment-7463057
Forgot to add, in the pic below you can actually see the crank girdle with the holes i drilled and tapped to take the RB26 windage trays, yes it does fit, clears the rods and crank and the crank scraper (not pictured) fitted in also, everything clears including the sump.
Also if your running a Tomei oil pump there are some extra block mods needed to make it fit, it wont bolt straight on, also the thrust main bearing is modded to provide extra oil to handle the 5700lb pull clutch pressure plate.
Edited by GTRPSI
https://www.sau.com.au/forums/topic/452355-oil-squirters/#findComment-7463058
More than a 7-8mm of clearance with Nitto rods and RB30 crank everywhere.
Even if it did foul, you could cut holes in those sections to provide 1mm of space between the rods or crank to the tray and take advantage of the crack scraper effect in those areas....id say the machinist is looking for easy work without hassels....(which there are none appart from drilling and tapping 12 holes and threads in the right place)
Edited by GTRPSI
https://www.sau.com.au/forums/topic/452355-oil-squirters/#findComment-7463298
Yes just a normal Bosch 240V drill.
Drill bit for the oil drains needed to be moved out right to the edge of the drills chuck for the last Cm as it was a little too short, you can see the edge where it was slipping, the drill bit below was my first pass at 8mm, then went up to 10mm which was a longer drill bit, 180mm and longer is what you really need to comfortably get through the block without changing the position of the drill bit to get the last 1cm or so through.
https://www.sau.com.au/forums/topic/452355-oil-squirters/#findComment-7466895
Sorry you asked for oil ways, they were done at 8mm for the main bearing feeds, just a normal drill bit from a drill bit set, did not have to be longer than a standard bit.
Then chamfer the hole a little to take the sharp corners off.
The grooves in the block for the RB26 bearing feeds were done with a steady hand and old bearings as guides with a dremmel with a cutting wheel, reason i didnt machine them out was because of a design/engineering issue with the design of the RB26 type of groove from the factory, i saw a area they could be improved.
The factory RB26 design is deepest at the center of the bearing and shallower where the oil feed comes out creating a restrictive point on oil exit into the channel, mine by hand are deepest at the oil feed point and gradually taper thinner as they approch the ends of the bearings.
After all that, the mains were line honed to ensure there were no high spots and that everything was straight and true for the crank.
https://www.sau.com.au/forums/topic/452355-oil-squirters/#findComment-7466900
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
