I put these pictures in the tas section because that's were I'm form but is pretty dead in the tas section. so here's my my block its a r31 series 2 block my engine builder machined my block and fitted rb26 oil squirters out if my old motor in to the rb30 . We did a few tests on a A8 block that was stuffed before going ahead . Im pretty happy with how it turned out :)post-134876-1420446965889_thumb.jpgpost-134876-1420446999866_thumb.jpg
  • Like 2
https://www.sau.com.au/forums/topic/452355-oil-squirters/
Cheers! I'd say it's going to get a fairly hard time I'm not one for mechanical sympathy, but spending so much on the motor this time around I reckon I'll use my head instead stead of my right foot haha
  • Like 1
https://www.sau.com.au/forums/topic/452355-oil-squirters/#findComment-7455462
I avoided it as the blocks a bit thinner than the RB26 ones there.
I ceramic coated the pistons and used Nitto rods with the built in oiling squirter holes.
And a handfull of other oiling mods to keep the oil down low like crack scraper, 26 windage trays on the 30 girdle etc....
https://www.sau.com.au/forums/topic/452355-oil-squirters/#findComment-7455572
There was talk about drilling a little hole on each side of the under side of the piston for the oil to cool down the tops of the piston the same as a 26 piston, he was also talking about drilling a tiny hole throw my h beam rod so they have bore squirters, but he wasn't to sure if it would change the strenght of the rod.
https://www.sau.com.au/forums/topic/452355-oil-squirters/#findComment-7455729
My Builder said if the bottom end lets go or breaks he will supply a new bottom end for me because he wanted to try these modifications to see how they go, he's also my dads good mate so I'm getting it done for near nothing , so I thought I might aswell go all out on it then, yeah it's also getting the crank scraper and windage tray of the 26 aswell :) I didn't no nitto made the oil squirters in the rods, but I had a set of precision Rods so that's why we used them
https://www.sau.com.au/forums/topic/452355-oil-squirters/#findComment-7455742
I buy them in bulk from the states, i am about to place a order on another batch end of this month.
You will need to adjust the fitment to your crank and rods, you need 1mm minimum space from the crank and rods to the plate and a bit extra to the thrust direction of the crank.
Took me a few evenings of grinding to shape to find what worked best for my application, the picture above is new as they arrive before shaping to fit.
https://www.sau.com.au/forums/topic/452355-oil-squirters/#findComment-7458199
do you have pics?
Wanting to do this, but engine machinist is saying it won't fit/work.
Would love to show pics saying otherwise.
https://www.sau.com.au/forums/topic/452355-oil-squirters/#findComment-7463035
Ive kept my build private and only shared it with 1 person here to help them out with their 3.2L stroker.
Here are some of the oiling mods....
Glyptal paint to aid oil drainback in a deburred block, note the annular grooves like in a RB26 block to provide extra oil and use RB26 race series bearings in a RB30 block.
Drilled out all the oil feeds, you can see the tip of the drill bit going into the main feed channel.
Drilled out the oil drains to 10mm, this will require opening up the head gasket oil drain points also.
There are lots of other little things that can be done to assist oiling and block strength such as Cryo treating the block, partial grout filling etc......
https://www.sau.com.au/forums/topic/452355-oil-squirters/#findComment-7463057
Forgot to add, in the pic below you can actually see the crank girdle with the holes i drilled and tapped to take the RB26 windage trays, yes it does fit, clears the rods and crank and the crank scraper (not pictured) fitted in also, everything clears including the sump.
Also if your running a Tomei oil pump there are some extra block mods needed to make it fit, it wont bolt straight on, also the thrust main bearing is modded to provide extra oil to handle the 5700lb pull clutch pressure plate.
Edited by GTRPSI
https://www.sau.com.au/forums/topic/452355-oil-squirters/#findComment-7463058
More than a 7-8mm of clearance with Nitto rods and RB30 crank everywhere.
Even if it did foul, you could cut holes in those sections to provide 1mm of space between the rods or crank to the tray and take advantage of the crack scraper effect in those areas....id say the machinist is looking for easy work without hassels....(which there are none appart from drilling and tapping 12 holes and threads in the right place)
Edited by GTRPSI
https://www.sau.com.au/forums/topic/452355-oil-squirters/#findComment-7463298
Yes just a normal Bosch 240V drill.
Drill bit for the oil drains needed to be moved out right to the edge of the drills chuck for the last Cm as it was a little too short, you can see the edge where it was slipping, the drill bit below was my first pass at 8mm, then went up to 10mm which was a longer drill bit, 180mm and longer is what you really need to comfortably get through the block without changing the position of the drill bit to get the last 1cm or so through.
https://www.sau.com.au/forums/topic/452355-oil-squirters/#findComment-7466895
Sorry you asked for oil ways, they were done at 8mm for the main bearing feeds, just a normal drill bit from a drill bit set, did not have to be longer than a standard bit.
Then chamfer the hole a little to take the sharp corners off.
The grooves in the block for the RB26 bearing feeds were done with a steady hand and old bearings as guides with a dremmel with a cutting wheel, reason i didnt machine them out was because of a design/engineering issue with the design of the RB26 type of groove from the factory, i saw a area they could be improved.
The factory RB26 design is deepest at the center of the bearing and shallower where the oil feed comes out creating a restrictive point on oil exit into the channel, mine by hand are deepest at the oil feed point and gradually taper thinner as they approch the ends of the bearings.
After all that, the mains were line honed to ensure there were no high spots and that everything was straight and true for the crank.
https://www.sau.com.au/forums/topic/452355-oil-squirters/#findComment-7466900
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
