Hi Guys,
First of all i know the questions regarding these motors are all over the site, But none seem to have the information im after at the moment!
Quick run down, Car is being restored at the moment and im not dropping a stock motor back into the car.
My current spec list of the engine is
Holset HX35 Twinscroll 12cm housing
6Boost Top mount twinscroll manifold
Greddy copy inlet/HKS copy Rail
750cc Injectors (Still unsure on what to go for)
3.5" Exhaust
I will be using a Link G4 Or Haltech ECU,Fuel wil be 99RON V-Power.
For my goal of around 500HP ATF, Or possibly 450WHP say, Everyone i have spoke to says keep my immaculate bone stock block and leave it be. Dont open it if i dont have too.
Other reports say the compression is too high (9.1 Isnt high though surely??) And you need a good free flowing setup to minimize back pressure (Again as i have, Apart from say cams??)
One part of me says leave it be, and if i come into knock problems i will rebuild the head, fit cams and ARPs, MLS Gasket.
Compression wise also surely fitting just a thicker gasket will ruin the stock quench pads ability to prevent knock to some extent am i right?
What are peoples opinions on this?
Car wont be dragged, Rarely if ever tracked, Will be purely road use.
R34GeeTeeTees motor is pushing out incredible figures, and still stock block barring head changes yes?
Thanks
Toff
https://www.sau.com.au/forums/topic/452371-rb25det-neo-tuning-advice/
There is a guy running 760hp on the stock bottom end of a neo here in WA. If it is timed/tuned and maintained properly, your 450 will be fine.
I think what they are referring to about "free flowing" is the intake and exhaust. You will need a decent intake pod filter and a hi flow exhaust to make sure it can breathe because I believe the hx35 flow around the same as the gt35.
You will need to upgrade your fuel pump as well.
By near stock everything i mean the block. Everything from intake to exhaust will be new (Ie Greddy plenum, 6Boost mani,3Inch exhaust, Haltech ecu, Upgraded fuel pump, injectors, Intercooler,Custom intake, Etc etc etc)
Only thing left stock is the block.
Sorry for not explaining myself properly, All supporting mods will be there!
And thanks sleptema, 760HP On stock bottom end is insane, Have you got a link to that mate?
On that note also i have found these injectors, http://www.ebay.co.uk/itm/201145001596?_trksid=p2060778.m2763.l2649&ssPageName=STRK%3AMEBIDX%3AIT
What do people think? If i could get a set of say Deatchwerks (600cc) And a matching fuel pump i would rather do that, But these seem ideal if they fit the larger greddy plenum injector locations. Stock NEO Injectors are too short by approx 10mm, So i could mabye shorten the spacers and fit larger washers to compensate for the locators but would rather not...
Thanks
By "near stock everything" I meant, bottom end, top end, inlet and exhaust manifolds, and damn near the turbo too (as in, a decent Hypergear highflow is able to approach that sort of power!).
As to injectors, any matched set of NEW Bosch 1000cc or bigger injectors, in whatever length and o-ring size you need, will do the job. Stainless ones are the best for E85, but the older ones still go alright. Look up Scotty on here (search for Xspurt injectors) for someone (in Australia, not the UK) that you could buy from fairly easily if you want someone who damned well knows what works.
Your in the UK yeah, have you looked at the Syvecs S6, much better ECU then the Haltech and you have the joy of having Ryan G from Syvecs and Paul Blamire of Zen performance as a local tuners who knows that ECU inside out
Also ID1000s with a Walbro 460 as an intank would take care of all your feeling needs
Price up a Walbro 255 and 600cc injectors then price up the Walbro 460 and 1000cc injectors, for whatever extra if any it would be worth it to cover any future mods
Fishing meaddifore comith, my uncle once told me plenty of people catch of little fish on a big rig but very few people catch big fish on little rigs :thumbsup:
Sorry mate i didnt really think about what you said haha, Thanks for that mate. 1000ccs will be plenty of headroom, But will i need injectors that big?Surely bigger isnt better in the case of injectors? Am i right in thinking i need adapters again for these?
I am in the UK yes, And i considered Syvecs briefly but dismissed it too quickly, Just checked there website and they can build plug and play harnesses, which may be worth looking at over the Haltech/Link options!
And thats good then, was on the lookout for an intank that would flow enough.
umm ....simple 255 intank walbro , 600cc , a decent turbo , 3inch exhaust ,proper clutch and a management of your tuner choice ..no need to touch the moto .... 400-450 easily doable
Would a 255 not be pushing it though to get that sort of power?
Just what i wanted to hear on the engine part!
Hahaha thankyou mate, As commented above surely i would be pushing a 255. 1000cc injectors may be the way to go then!
  • 2 months later...
Little thread bump,
Just on with ordering bits up for the motor (Delayed i know) And currently have:
Thats were im thinking at the moment, Going for the UNOPENED Engine option as its a mint engine currently so no point in splitting it right? If the headgasket goes at a later date (Should it though if tune is correct?) I will have to put one in.
Goal for power is 550Hp At the Fly, so roughly 470Hp ATW, Or 360RWKW thereabouts.
Thanks
Toff
yeah I would personally not get fancy with manifolds and special "race spec turbos", Twin scroll and a GT35ish turbo sounds overkill and if not done right you could end with a dog of a thing when a simple stock manifold and hypergear will guarantee you results. The 3076 is king in your power range, Look up Mafia's thread, the sound is awesome.
Are you using 2 wastegates?
Edited by AngryRB
Thanks for the responses guys.
turbo and manifold I already have, Turbo was cheap at £450 new and there supposed to hit 600hp max so just a tad over my goals.
Need to dig a few dyno graphs/posts out of the turbo, supposed to be very responsive with the spec But we will see.
Will be using 1 large gate as it merges into one at the bottom, turbosmart 50mm perhaps.
what else would you change on it? 100% leaving intermale stock for now.
On the manifold point as well I thought stock was shockingly restrictive at 350rwkw onwards? Hence people killing motor's and hypergear cutting that one up and making a custom one? Twin scroll should bring the boost threshold down too.
For future reference I will put up graphs once the car is finished.
Thanks!
420rwkw (564rwhp)
Std NEO, std manifold externally gated, hyper gear turbo @27psi.
Run 420rwkw on Springy motors dyno and on my dynapack.
Credit to their work, welding is awesome (HAVOC fabrication)
id1000cc (increased base pressure)
dual walbro 400 pumps
std cams and springs
Hypergear ATR45SAT
splitfires would not hold up but D514a work fine at 0.8mm
Haltech plat Pro with wideband and flex sensor.
E85
11059493_10152601384742133_5126814348893
  • Like 2
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
