Hi Guys,
First of all i know the questions regarding these motors are all over the site, But none seem to have the information im after at the moment!
Quick run down, Car is being restored at the moment and im not dropping a stock motor back into the car.
My current spec list of the engine is
Holset HX35 Twinscroll 12cm housing
6Boost Top mount twinscroll manifold
Greddy copy inlet/HKS copy Rail
750cc Injectors (Still unsure on what to go for)
3.5" Exhaust
I will be using a Link G4 Or Haltech ECU,Fuel wil be 99RON V-Power.
For my goal of around 500HP ATF, Or possibly 450WHP say, Everyone i have spoke to says keep my immaculate bone stock block and leave it be. Dont open it if i dont have too.
Other reports say the compression is too high (9.1 Isnt high though surely??) And you need a good free flowing setup to minimize back pressure (Again as i have, Apart from say cams??)
One part of me says leave it be, and if i come into knock problems i will rebuild the head, fit cams and ARPs, MLS Gasket.
Compression wise also surely fitting just a thicker gasket will ruin the stock quench pads ability to prevent knock to some extent am i right?
What are peoples opinions on this?
Car wont be dragged, Rarely if ever tracked, Will be purely road use.
R34GeeTeeTees motor is pushing out incredible figures, and still stock block barring head changes yes?
Thanks
Toff
https://www.sau.com.au/forums/topic/452371-rb25det-neo-tuning-advice/
There is a guy running 760hp on the stock bottom end of a neo here in WA. If it is timed/tuned and maintained properly, your 450 will be fine.
I think what they are referring to about "free flowing" is the intake and exhaust. You will need a decent intake pod filter and a hi flow exhaust to make sure it can breathe because I believe the hx35 flow around the same as the gt35.
You will need to upgrade your fuel pump as well.
By near stock everything i mean the block. Everything from intake to exhaust will be new (Ie Greddy plenum, 6Boost mani,3Inch exhaust, Haltech ecu, Upgraded fuel pump, injectors, Intercooler,Custom intake, Etc etc etc)
Only thing left stock is the block.
Sorry for not explaining myself properly, All supporting mods will be there!
And thanks sleptema, 760HP On stock bottom end is insane, Have you got a link to that mate?
On that note also i have found these injectors, http://www.ebay.co.uk/itm/201145001596?_trksid=p2060778.m2763.l2649&ssPageName=STRK%3AMEBIDX%3AIT
What do people think? If i could get a set of say Deatchwerks (600cc) And a matching fuel pump i would rather do that, But these seem ideal if they fit the larger greddy plenum injector locations. Stock NEO Injectors are too short by approx 10mm, So i could mabye shorten the spacers and fit larger washers to compensate for the locators but would rather not...
Thanks
By "near stock everything" I meant, bottom end, top end, inlet and exhaust manifolds, and damn near the turbo too (as in, a decent Hypergear highflow is able to approach that sort of power!).
As to injectors, any matched set of NEW Bosch 1000cc or bigger injectors, in whatever length and o-ring size you need, will do the job. Stainless ones are the best for E85, but the older ones still go alright. Look up Scotty on here (search for Xspurt injectors) for someone (in Australia, not the UK) that you could buy from fairly easily if you want someone who damned well knows what works.
Your in the UK yeah, have you looked at the Syvecs S6, much better ECU then the Haltech and you have the joy of having Ryan G from Syvecs and Paul Blamire of Zen performance as a local tuners who knows that ECU inside out
Also ID1000s with a Walbro 460 as an intank would take care of all your feeling needs
Price up a Walbro 255 and 600cc injectors then price up the Walbro 460 and 1000cc injectors, for whatever extra if any it would be worth it to cover any future mods
Fishing meaddifore comith, my uncle once told me plenty of people catch of little fish on a big rig but very few people catch big fish on little rigs :thumbsup:
Sorry mate i didnt really think about what you said haha, Thanks for that mate. 1000ccs will be plenty of headroom, But will i need injectors that big?Surely bigger isnt better in the case of injectors? Am i right in thinking i need adapters again for these?
I am in the UK yes, And i considered Syvecs briefly but dismissed it too quickly, Just checked there website and they can build plug and play harnesses, which may be worth looking at over the Haltech/Link options!
And thats good then, was on the lookout for an intank that would flow enough.
umm ....simple 255 intank walbro , 600cc , a decent turbo , 3inch exhaust ,proper clutch and a management of your tuner choice ..no need to touch the moto .... 400-450 easily doable
Would a 255 not be pushing it though to get that sort of power?
Just what i wanted to hear on the engine part!
Hahaha thankyou mate, As commented above surely i would be pushing a 255. 1000cc injectors may be the way to go then!
  • 2 months later...
Little thread bump,
Just on with ordering bits up for the motor (Delayed i know) And currently have:
Thats were im thinking at the moment, Going for the UNOPENED Engine option as its a mint engine currently so no point in splitting it right? If the headgasket goes at a later date (Should it though if tune is correct?) I will have to put one in.
Goal for power is 550Hp At the Fly, so roughly 470Hp ATW, Or 360RWKW thereabouts.
Thanks
Toff
yeah I would personally not get fancy with manifolds and special "race spec turbos", Twin scroll and a GT35ish turbo sounds overkill and if not done right you could end with a dog of a thing when a simple stock manifold and hypergear will guarantee you results. The 3076 is king in your power range, Look up Mafia's thread, the sound is awesome.
Are you using 2 wastegates?
Edited by AngryRB
Thanks for the responses guys.
turbo and manifold I already have, Turbo was cheap at £450 new and there supposed to hit 600hp max so just a tad over my goals.
Need to dig a few dyno graphs/posts out of the turbo, supposed to be very responsive with the spec But we will see.
Will be using 1 large gate as it merges into one at the bottom, turbosmart 50mm perhaps.
what else would you change on it? 100% leaving intermale stock for now.
On the manifold point as well I thought stock was shockingly restrictive at 350rwkw onwards? Hence people killing motor's and hypergear cutting that one up and making a custom one? Twin scroll should bring the boost threshold down too.
For future reference I will put up graphs once the car is finished.
Thanks!
420rwkw (564rwhp)
Std NEO, std manifold externally gated, hyper gear turbo @27psi.
Run 420rwkw on Springy motors dyno and on my dynapack.
Credit to their work, welding is awesome (HAVOC fabrication)
id1000cc (increased base pressure)
dual walbro 400 pumps
std cams and springs
Hypergear ATR45SAT
splitfires would not hold up but D514a work fine at 0.8mm
Haltech plat Pro with wideband and flex sensor.
E85
11059493_10152601384742133_5126814348893
  • Like 2
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
