  • 2 months later...
been looking around but couldn't find information on this
does anyone know if half height EV14 injectors with height adapter will fit the r34 GTT?
reason i ask is the r34 GTT uses 3/4 height injectors but the plug sits really close to the plenum, looking at the 1/2 height injectors i have sitting around i'm a bit worried that it won't fit
or will it be ok if i spin the injector around so the plug faces downwards to give it more space?
secondly, the bosch injectors I've got do not have lower O rings, they've got one of those square section rubber seats like those on the GTR, like this:
https://www.efihardware.com/products/1489/injector-lower-square-section-seal-large
Do I have to convert this to O ring so it will seal properly?
just needed to make sure before i start to gather the parts and pull things apart
You are making this harder than it needs to be.
PM scotty nm35 and tell him what you want.
Don't ask questions. Just do what Ben said and be done with it. Scotty will give you the right injectors are the right price.
Yeah I know it's not something most people do when they change injectors. I would have contacted Scotty for a set of 3/4 height ones if I don't already have these half height injectors lying around taken out of my old car. I'm just seeing if anyone has done this before, if not it's ok I'll just have to trial fit it first to see what I need
Edited by chiksluvit
I assume you have 14mm 1/2 length injectors? I can supply the height adapters if you need them. Do you have the plug adapters?
Should just drop into a 34 with the correct adapter to make them 3/4 length. If the injectors have been laying around a while I would be a little worried, enough to get them cleaned/tested anyway.
Without seeing a pic I have no idea, but it isn't 14mm now is it. I assume the lower retainer for the oring has been modified to fit the square Oring, but you should be able to get a 14mm Oring to seal without falling off. PM me if you need some.
Notice there is nothing to stop the Oring falling off anymore? It has been chopped off to accommodate the new square GTR Oring. I can supply the round 14mm Orings but they may slide around and fail to seal in the plenum properly I guess.
Not the lower tip part, the part where the Square Oring is at the moment. The standard Oring will fit back on, it will just slide around now the captive plastic part is gone.
  • 4 months later...
Are these what are referred to as the ID1000? In the below link..
What is the best price you're all getting your 750-1000cc r34gtt injectors for?
Are the below suitable and is this a good price?
http://m.ebay.com.au/itm/6-x-1000cc-Bosch-E85-FG-XR6-turbo-upgrade-fuel-injectors-0280158040-/151333893801
No they are not ID1000s. ID stands for Injector Dynamics which is a crowd that takes standard Bosch EV14 injectors and mods them. There are other vendors doing the same thing. This eBay vendor appears to be doing the same thing, only these are effectively "no-name". They might be fine. They probably are fine. But they are not ID.
If you want our recommendation, just ask Scotty.
Machining the little holes on the tip of the injector can help with a bit of extra flow through them, except in the case of the injectors you linked. With them it makes no difference.
How critical is 1% flow to you? What if it was 10% less on one cylinder, what do you think the outcome would be?
Bosch tell me there can be up to 10% flow difference with the new e85 injectors, similar to the older 2000's.
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
