Not sure if anyone has done this yet but decided I might as well write up a tutorial upon completion of mine
Tools needed:
1x small phillips head screwdriver
1x small flat head screwdriver
Linear polariser film (preferably with adhesive side, I got mine from http://www.3dlens.com/shop/lcdpolarizer.php)
Acetone
Scalpel/Razor
Procedure:
1. Remove climate control from car.
2. Remove the temperature knob along with the nut behind it
3. Remove the 4 screws holding the front half of the unit to the back half
4. Using the flat head undo the 4 clips, and the front part should pop off
5. Undo the the 2 screws holding the back circuit boar, then push on the part where the plug goes to slide it out
6. Undo the 4 screws holding the front circuit board to the face
7. You should be able to pop the circuit board out now
8. Now comes the tricky part, using a scalpel slowly try and peel back the existing polarising film. Easiest to work from the corner and slowly sliding the scalpel along the glass
9. If there's adhesive residue left over on the screen, then use acetone to remove it
10. Time to apply the polarising film, if you place it the correct way it should look normal (white backlight with black writing), but if you turn it 90 degress, it'll reverse the colours
11. Once your happy with it, cut the film to size and apply to the LCD screen
12. Reassemble the climate control unit and reinstall into car, now you should have something that looks like this
Edited by shinobi_s14
  • Like 1
  • 1 year later...
  • 8 years later...
Does anyone know for this, before removing the original film on the screen, should I be able just put the new film over it before removing the unit to test to see if the film I bought is correct? A bit of a stupid question but I tried it and it didn't work so I don't know if the film is incorrect or if the original film needs to be removed to see the effect.
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
