Hello, So ive just brought my very first turbo car (R33 Gtst), im learning fast but I still need some help. so ive brought a dual stage boost-T ive hooked it up and car seems to run sweet, cant really test it till I get a boost gauge tomorrow tho.
Now I know this question has been asked LOTS, but trust me ive posted on forums, and searched internet for ages but got nothing, so why not ask the experts?
Now my question is: Is this hooked up correctly?
https://www.sau.com.au/forums/topic/452410-boost-t-install-help/
I'm guessing it's not hooked up right.
If that T piece shown in the middle of those three bits of hose is just a plain T, and there is no restrictor involved in the line going down to the wastegate actuator, then it will do very little.
A "boost T" is a controlled leak of the boost signal. There is an adjustable valve in the "T" that lets more or less of the boost signal out of the line. There must be a restrictor so that the flow (that ends up leaking out through the "boost T") through the restrictor suffers a pressure drop.
The reason they are called "boost Ts" is that the valve and the restrictor are bundled up into the same body (the T) and they are installed into the boost line as if they were a T piece. The signal source and actuator being on the two connections and the other leg of the T being the hole through which the air is leaked out - hiding somewhere on/in the body of the T. Look at http://www.turbosmart.com.au/wp-content/uploads/2011/10/5483.jpeg to see how a typical one is installed.
Its a dual stage boost T. I understand what you mean about needing a restrictor in the middle but how I've hooked it up seems to be the only way? Maybe I'll just buy a normal boost T and hook that up seems a lot easier.
Edited by AshR33Gtst
OK, well now that we know the actual type of boost controller, 10 seconds spent on Turbosmart's site provides the following instructions
http://www.turbosmartdirect.com/Product-Categories/Manual-Boost-Controllers/Dual-Stage-Boost-Controller-Blue.html#instruction
Click the Instructions link on that page or click the following link direct to the file.
https://system.netsuite.com/core/media/media.nl?id=177080&c=830533&h=946a342eea68c3fc2e82&_xt=.pdf&ck=lmUxAvMCAh_EXjAZ&vid=lmUxAvMCAibEXn3O&cktime=131827&addrcountry=AU&gc=clear
Edited by GTSBoy
That's hookd up right, it's a boost "T" which means it bleeds boost pressure out of the wastegate line via the T though an electric valve, this one does so by two different size valves depending on which one is switched on
A long time ago when turbos started becoming popular a mate put a single cam CA18 turbo in a canary yellow 1200 coupe, to lift the boost level he put a T in the wastegate line then ran a meter of hose off the side of the T then cut 1 inch at a time till he got the desired boost level, this worked a treat
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
