Corporate-Logo-black-background_zpscc39a
SAU.NSW officially would like to thank Nulon for hosting this wonderful event about lubricants
Please watch above video!
Topic: Nulon Oils and Additives
Day/Date: 18th February
Time: From 6pm to approx. 9pm, but be there a little earlier. End time is just approximate, please be aware that most tech nights that we have held have gone over time.
Address: 17 Yulong Close, Moorebank. As soon as you pull into Ylong Close you can see us at the end on the right.
Google Maps URL: https://goo.gl/maps/KXuIi
Parking: Plenty of Parking in their car park!
Food and Drink: Snacks and drinks will be provided with thanks to Nulon
This event is Free for Members - although non-members still have time to apply and pay for membership!
Each SAU NSW financial member registered and in attendance for this event will recieve a bottle of synthetic oil and fuel treatment : for any special requirements please let us know in this thread and we will take note and see what we can do
Please also put up in this thread any Questions you would like to have answered on the night.
Spots are limited with a minimum of 25.
This tech arvo is held with thanks to Nulon. The Night will be on lubricants and additives including their effectiveness for both road and race applications. This will be a very informative night!
One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general.
When attending one of Skylines Australia NSW events please try to:
* Be aware of surrounding environment and act accordingly.
* Drive courteously on the state’s roads as a true enthusiast should.
* Understand how important it is to maintain the good name of SAUNSW and thus, treat others accordingly.
* Any misbehaviour will not be tolerated and you will be asked to leave.
*** All advice and demonstrations given by workshops, professional practices and factories for SAU.NSW Tech Nights are the responsibility (of accuracy) of the establishments - not the car club.
*** Details may change. check back regularly.
The List
1. Crashdown (P)
2. Terry_GT-R34 (M)
3. Redline_GTR (E)
4. stagea pete (M)
5. RiseofBrutality (M)
6. RBrennan25 (M)
7. kila32 (M)
8. levinboy (E)
9. 34GeeTeeTee (VP)
10. Carmen (M)
11. Aggroman (E)
12. sammi_d (M)
13. GoldZilla (VP)
14. Cassbo (M)
15. WAGON_BOY (M)
16. Daleo (E)
17. MrStabby (M)
18. Jordy32 (TBC)
19. ianjb (M)
20. Greg_FR33GTR (M)
21. GTofuS-T (M)
22. Hanso (M)
23. MrFijiGold (M)
24. Deka (M)
25. skak007 (M)
26. Mr33yo (E)
27. Scott Black (NM)
28.
29.
30.
Just so everybody knows. I have added the following to the bottom of first post. It is just some general rules that we ask people to follow at our events.
  • Like 3
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
