Hi everyone, recently I installed a turbosmart boost tee on my series 1 r33 skyline and have been having issues when I reach full boost. Before the boost tee, I installed a new larger fmic to replace the stock side mount. Due to the larger size of the new cooler the car was only running half of the standard 7psi boost it had with the side mount. I was told this is normal and installing a boost controller to wind the boost back up to 7psi would be the go. So I followed a thread from this forum to install the boost controller and everything seems to be installed correctly but when I come onto full boost (7psi) the car splutters repeatedly until I let off the throttle :/ I found that if I remove the boost tee and connect the standard boost solenoid back up the problem goes away. Although the car is now only running 3.5psi. If anyone has heard of this or has some idea as to what's going on and how to fix it let me know. Any help is highly appreciated. Thanks :)
Edited by BRADR33
https://www.sau.com.au/forums/topic/452417-r33-boost-issues/
Your 3.5 psi is nothing to do with the larger size of the new cooler and everything to do with a massive boost leak that you have somehow managed to introduce, probably by not doing up an intercooler hose clamp properly.
It is also conceivable that you bumped/dislodged something else whilst installing the cooler.
Your poor old turbo is now spinning like a Mofo to try to make boost, regardless of the boost controller. Put the boost controller on and it is now spinning even harder. It's sucking lots and lots of air through the AFM, pissing it out into the breeze through the leak, and the ECU is calling a halt to proceedings when the AFM signal gets too high. It's called R&R.
I strongly suggest you take a long and close look at the pipework and do a lot of reading and research on the topics of R&R and the death of ceramic Skyline turbos when overboosted before proceeding.
  • Like 3
Originally I thought the same when I first installed the new intercooler. I triple all my connections and the tightness of all the hose clamps but found no leaks. I took it to a mechanic to see if they could find the leak and they ran it on a vacuum tester. According to them there is no leak and the size of the cooler is why I'm not getting as much boost. They were the ones who suggested installing a boost controller to me.
Well, it's simply not true. The "size of the cooler" has no impact on how much boost you make unless it is tiny tiny tiny and causing a massive pressure drop (like blowing through a small hole). As the situation is actually the opposite way around (a larger cooler should have less pressure drop), it would have to be a terribly poor quality core with massively bad design to cost you an extra 3.5 psi.
There is one other possible explanation. The time honoured "rag in the intercooler pipe" could do it to you.
This will end in tears if you don't address the boost issue. Listen to GTSboy.
1. remove the boost tap until you are 100% sure you're not overboosting.
2. pressure test the intake - very different to vac testing. However a minor leak is actually normal. the stock BOV has a hole in the side of it.
3. use an aftermarket boost gauge and don't go much over 10 psi if you value the life of your stock turbo.
4. Let us know how it goes
  • Like 1
  • 4 weeks later...
Hey guys, sorry I took so long to get back to you but lack of funds kinda prevented me from doing so. Just recently I picked up a genuine autometer mechanical boost gauge of a mate for cheap and installed it into the car. I've tested both the stock and after market intercooler set ups and I am running the standard 7psi on both. So problem solved, no leaks, the standard boost gauge is just a lying piece of shit :) thanks for all the help guys ?
Standard boost gauge isn't a lying piece of shit :) ... it reads in torr / mmHg, which many mistaken for psi.
7x100 mmHg = 1bar OR 14.5psi, so if you're seeing it at 3.5 x100 on your dash then happy days.
    • Ha ha ha, mine loves to spend, all on the dogs (they're our kids, and her spending would likely rival that of some people raising children!) the only benefit is, her spending is tax deductible as she runs a business in the dog industry 😛 The above all means she can spend race car budget quicker than I can. 😛 That and a lot of the things I want are very expensive, and I can be a bit "you want how much for that?!" And at other times overly impulsive. Or I start the w days of research, get to day 1.5 and get really annoyed that no one will advertise actual specifics and it's just marketting BS and I go "well, now I don't want anything to do with that now!" Also I hate paying lots of money for something I can make from $50 in materials. Then I get the shits halfway through making things and wonder why others who just buy parts have more fun... 😛
    • Their 240Z with the RB26 would be a real nice thing to have in a garage to come out for an occasional weekend cruise It's such a cool thing in so many ways Sadly, we have a blue 240Z shell that I walk past every day, just sitting outside a shed at work, it has been slowly disintegrating and falling apart into the ground for the last few years, the owner cannot be found, and I am unable to "claim it" I've been told by work and the RMS, the rust in the body is excessive though, and it has had most of the salvageable stuff, like panels, trim and switch gear stripped off it over the last year or two, work keeps threatening to put it in one of our metal scrap bins, I wish they did though, as it makes Mark sad walking past it
    • Good tips, I like it! 😂😂 My wife is a LOT more frugal than me so it's only me we need to worry about! A splurge to her is buying 2 pairs of socks in one visit at Kmart!
    • Haha, the appropriate response to the question "Is this new?" is "I've had this for a while.". With the unspoken small print that a while may be the time since this morning or five years ago   And to be fair I learned that from the best, i.e. my wife. Because it goes both ways.
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
