Pinging is detonation.
That's great you trust who've put the gauge on the car and probably set it up correctly.
Is it possible it doesn't work? Like a broken wire? See what I mean about trusting a gauge . How can you when they can either be setup incorrectly or fail.
When making large changes to a tune and swapping ecu to a random one is definitely large, you really should go on a dyno to check what's going on.
Like I said,report back. Just because a car runs rich doesn't mean it won't detonate, and just because a gauge doesn't show detonation doesn't mean much.
What gauge and sensor is it?
Running an ecu with an unknown tune on it is plain stupidity regardless of AFR's or whether it's not knocking! Whats the timing map look like? What octane fuel was it tuned on?
If you cant answer these questions all the gauges in the world wont save your motor! Next question is will your tuner have the software to even look at the ecus current state of tune?
So reality is you will need to chuck it on a dyno to find these things out yeah?
By the time you pay a tuner to strap ya car to a dyno and look at your tune you may as well actually pay for a custom tune that is setup for your specific setup as it aint gunna cost that much more as the car is sitting on the dyno reasy to go! If you don't take this advice sell your skyline to somebody who deserves to own it as you clearly do not!
Edited by Mick_o
personaly you,how many cars you have boosted?i think none,just sitting to laptop and talking how to live,i deserve that car more than you for sure,cause normal guys told me good advices,so i dont see any point of beeing in this forum,cause i am good in cars,just started this topic to get some experience with exact ecu,not to ask your permision to live,even by that,i wont tell full results of Dyno,that was made this morning and by the way,it went much better,than i expected and i already got answer from Blitz,what that Ecu is made for,so leave your bullshit to yourself,cause all your advices without experience are worseless,go and do something in garaze,not in your chear by the pc,PEACE
  • Like 1
tell me at least one good reason why it had to?usually engines blow up because of lean a/r,too much boost and detonation held for too long,how can such ecu effect blow off?its only richer fuel map,boost and fuel cut eliminated.
Ok,end of story,i got nothing here,but few guys contacted me on other forum and they shared their experience with that ecu,even one of them asked me to inform,when i will replace it with standalone,so he can buy it from me,good luck,dont blow your engines,while playing NFSU
You are a legend.
And have made me laugh.
The pro race gauge must be good, along with a random ecu tune.
I'm calling bullshit that you got the car on a Dyno and it ran well, but you know what, I don't care either way.
You have made judgments about me based on nothing. My statements in this thread are based on the stuff you have said. Which is funny.
I would never trust a " pro race" detonation gauge no matter what, unless of course I installed it and set the sensitivity and frequency.
I would never use a random tune.
But hey, im not you. I'm glad it worked out for you.
Cmon, tell us the results.
Hahaha at this guy! What a dick!
Wow. Joining the pack mentality, that's so tough.
I wouldn't run one of these ecu's either, but - Blitz are well known tuning company, quite likely they'd done some tuning and research as to what works best as an 'average tune' for the basic upgrades of intake, exhaust, boost increase, and it could feasibly plug in and run reasonably well. Could. Not to say it would, but could. And sounds like no one on here but OP actually has tried and knows. If i had one, and a dyno and monitoring gear handy, i'd plug it in and see how it runs too.
Wow much hate for such a simple thing. Sure there are always variables with a remapped ecu, but not really any need for amount of stupid in this thread.
Firstly, if old mate has put a wideband on the car and got afrs at about 11.5 to 12, then it clearly isn't tuned for bigger injectors, otherwise the the afrs would be really lean. Secondly, if it's been tuned for a bigger turbo then that doesn't really matter much, because it's been tuned to handle more air being forced in than a stock turbo can pump, so it certainly isn't going to lean out in the top end. Sure the timing might be a bit generous in some areas, but hey, if it isn't pinging it's arse of then who cares. There's plenty of people who have paid good money for a proper tune and have gotten a tune that's killed their engine, so it isn't the best option all the time. Hell, there's probably plenty of people out there who are driving around with a stock ecu, turbo, with the boost wound up and have a dodgy fuel pump causing the car to lean out and do more damage than what this ecu will probably do.
The replies in this thread just remind me of pretty much every flat spot thread on this forum, where all anyone can respond with is "it's rich and retard". All anyone's been able to say in this thread is "remapped ecus are shit". At the end of the day, some generic remapped ecu off the internet is still better than some tuners out there. I'm sure you've all seen at least 1 car with a "safe tune" where the back of the car above the exhaust is black with soot. Yep, real safe, cause if you hit boost you'll be out of fuel before you get a chance to grab the next gear.
  • Like 1
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
