Ok so I'll start at the beginning my R34 Gtt series 2 had the exhaust wheel snap off the turbo, as I am on a budget I bought second hand standard turbo, running standard boost it drove fine for about a week, then all of a sudden I noticed a noise like a squeal and my boost dropped off, so immediately stopped, it hasn't over heated nor is the oil creamy so was hoping someone might have some idea don't want to pull off the head if it's just a cracked turbo internally is there some way of checking I noticed aswell that I can idle the car no squeal or anything seeming wrong but if I rev I'm getting boost but when it hits max it drops off and I get exhaust fumes out my radiator, any help or tests that I can do would be greatly appreciated I'm on a budget but if it comes down to it I'll pull it off the road until I can scrape enough coin to do turbo and head/ gasket if required but that'll take a long time to save
https://www.sau.com.au/forums/topic/452443-need-help-r34-engine-issue/
Sorry should of been more specific the squeal was the split in the header tank and I did use brand new gaskets etc when fitting the turbo, I'm more looking for a test to work out wether the exhaust gasses are entering the cooling system from the head or internally in the turbo
Ask at Supercheap or Repco. Combustion Leak Tester.
You should be able to buy a kit that will tell you if there is Exhaust gasses in your coolant by the change of colour. (blue to yellow)
Instructions will be on the kit and should take less than 20 minutes.
You can also do a quick test by removing your radiator cap to see if your getting bubbles.
If so:
It will be the head/head gasket.
Edit: Not to say your Turbo isn't screwed also
Edited by Sinista32
I am getting bubbles in the radiator that's how I know that the exhaust is leaking I'm just confused as I thought the head/ head gasket would've allowed coolant into the oil or vice versa ill do a compression test and see what I get, do you know what it should be reading if the engine is within spec, and the only reason I'm suspecting turbo at all is because it's the only thing that's changed and is oil and water cooled so I thought there's a possibility that it could cause exhaust in coolant should a seal fail or housing crack, and because it idles fine but when I accelerate the boost guage hits 7 then drops straight to zero so stops boosting
I'm always surprised how people think a head gasket failing will always mix coolant and oil.
Looking at a gasket it's the least likely scenario. There's heaps of coolant galleries and not many for oil. So typically a blown gasket leaks coolant only.
For now the leak is small. Keep driving and you will eventualy see oil in the water. Second hand turbs never a good idea. As for turbo causing gasses in the radiator - no.
So there is no chance that the turbo cracked internally and is feeding exhaust gasses through the cooling section of the turbo out into the cooling system, and ill do compression test ASAP and post results, in order to keep driving the car ill have to get new radiator because too tank on radiator split open so it would've had to over pressurise the cooling system
I do understand what your saying but wouldn't you still likely get an overheating issue or smoke out the exhaust?
No. It will overheat when it loses enough coolant. It only creates steam when a fair bit is going through. Small leaks don't show up easily.
That's why there are test kits available for checking for the precede of exhaust in the coolant.
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
