ok what will/do they check/go over at this shit hole of a place!? first regency defect just a couple weeks ago want to "TRY" past first go! any pointers tips help would be wonderfull!!!!!
and also any Adelaide skyline kids here wanna join my facebook club/group it is : Adelaide Skylines Club for that extra bit of forum help! :) and cruises!
https://www.sau.com.au/forums/topic/452469-adelaide-regency-defctzzzz/
They will check over everything. They know what they are looking for and will look for it.
Therefore your car needs to be completely legal. Doesn't need stock exhaust but has to be be legal volume,so can restrict it and pack woth steel wool etc.
Can't see first pic either.
What mods does your car have aside from intercooler?
ahhh shit that sucks then lmao not keen at all!! trying everything i can to my little knowledge about it that i can do!! :(
first pic id my defect notice lol it really makes no sense at all lol only mods is exhaust, 18" rims ( putting stockies on with snow tyres that my mate lent me lol will they pass them still? ) front mount but taken that off and replaced my chopped front reo bar to a full reo bar and standard front bumper so i can hook up the normal indicators as my other bart had stupid LED ones the cop didnt like!! i had my standard BOV only blocked off with the old coke tin trick and cop caalled it a " BLOW BACK VALVE " and apparantly aftermarket illegal defect lol!!! oh and i had my clear led tail lights that i have changed to normal cop didnt like them either!
You got an interesting cop! 18" rims are fine, unless there is something weird about them? As GTR's came with 16" rims therefore can go 2" larger (this is due to Speedo reading etc.). Not sure with the other stuff.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
