Wtb R34 Gtr - Anyone Seen This Gtr ?
When your custom manifold and custom single turbo get looked at by the police, and you didn't spend $1000 + on Mod plates and you get a yellow stick for it instead of going sleeper stock look, then all good. Besides ones the OP looked at were cheaper range singles anyway. Not to mention additional costs upon tuning and what not if you were to switch back to twins for a defect..
For circuit and road, definitely low mount twins. But for straight line top end and drags, you can't beat a big single turbo. a 400kw twin -5 setup and a 400kw single 3582 setup are very different. The single turbo give much more punch on boost where as the twins give wider power band
Size of the turbo/s has more to do with a wide or narrow power band than twin vs single configuration
Are people seriously going to argue this single vs twins thing on paper
Too many variables to generalise anything about it
I believe the points I've made here are relevant rather than typical "twin is better than single cos there 2 of em brahh". Only two reasons one goes single turbo on a GTR.. that's if the engine went bang or the turbos themselves went bang. I'm no expert with skylines but i'm fairly sure there's a few kits out there direct aftermarket bolt on twins that don't sit up against the rocker cover. Anyway regarding the OP's first question that car is in doubt not worth flying a state away and back to see it, I mean come on man look at it.. swede / coon / tryhard / top bloke ect not to mention cop magnet and a stock motor with the hefty price tag of $43k.. surprised no one on here can call it not worth it compared to some others for another 3-5k?
They would be the most likely reasons on a r34 GTR skyline worth 40k someone would waste $2-3k on manifold / $2k on a turbo and bother with all other on off bits piping/lines ect.. were not talking a $6k GTST to make it from 200hp to 230.. lol. I do forget a lot of this after market stuff is direct bolt on to rb blocks so I guess that's easy in that respect however your still battling the price tag to justify it on a r34? I don't know about you lot but if I was to change a turbo set up from either stock or aftermarket twins to an aftermarket HUGE single setup I would wage costs. Anyway why bother debating this your a "vic club member" you live in Victoria and we have the harshest road laws in the country. Your a moron if you live in a big city and think you won't get pinged in a skyline for a huge defect and be down at Vicroads getting EPA / underbody inspection and restore your rocket to 'stock' get it cleared again $$$ and then put all your go fast bits back on? Lol.
If your not driving like a cock, and dont talk to them like a cock... They generally dont give 3/5ths of f*ck all if its a single and will pay more attention to the pod filter (NSW COPS ANYWAY)... i know the VIC cops are more KENTS
First hand experiences i assure you, The turbo sits so high that i had to cut some of the reo out to close the bonnet :D
Just as reference, a mod plate wont help you if they want to bend you over proper.
Also Twins Eat a Fat one, .. Just to clear that all up :)
  • Like 3
price was negotiated with the one in vic to quite a reasonable price - have a few good mechanic friends up in vic who checked the car out for me all looks good - confirmed that the front has not been in an accident after thoroughly looking at it - still thinking of flying up since all seems well drives well and its stock which is what i initially was looking for - if theres some 3k more then point it my way and ill check it out asap !
lol other then that stil enjoying the single v twin discsussion :)
 Share
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
    • NO HITS PRICE DROP   ENGINE - $8.5k ONO TRANSMISSION - $1.8k ONO
    • If it has had a code in the recent past, the code should still be there waiting to be read.
