I agree, you don;t need to sign it or anything.
can leave in wallet and not care, where as always looking for the booklet the night before.
I was just surprised when opened letter, thought they had sent the wrong thing.
  • 2 months later...
  • 3 weeks later...
No he's not...
Updated since no one else has done it while I found a real job. Probably a few mistakes, so let me know
Lol I know I'm not winning but I'm happy with 4th in modified for now with the competition I'm up against and my potato skill level. :)
  • 4 weeks later...
So looking at this it seems that round 8 at Broadford has disappeared?
We couldn't get a date :(
They are heavily booked, we have expressed interest for 2016.
We have a Sandown 30th of Jan to start the year.
Spewing, does that mean this years championship is over now?
There isn't much going on in December this year.
There is a single PI and Winton, both on the same day, both the day after DECA.
Dave, what a big round to miss when leading by 1pt leaving Aaron to clean up.
So is the final championship being updated - How many rounds get dropped this year?
Any updates to this guys? If the championship is over what were the final results?
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
