E85. I thought it would of made more but oh well have to ask Trent why it couldn't. It is a unopened 170k s1 engine. I'm thinking I should of went with the sat45 turbo now.
The boost curve is what surprises me because my other ss2 internal gate is full 21psi boost by 3750rpm and the curve looks a lot better than that and then goes completely flat.
I'd replace the gasket between the runners and the plenumn. Some S1 are metal, later ones are rubber. Mines an S2 and was rubber, it started leaking and we didnt pick it up for a long time.
I used a cometic gasket from kudos ms.
Did u end up getting a front splitter made up?
im looking for ideas, want to make one soon.
Hey mate nah not yet but it will be getting sent back in to get one made up at havoc fab. Looking at something like this.post-84279-14343233710606_thumb.jpg
Yeh I looked through his build thread and found it there. Also speaking to top stage composites atm as well and might just bite the bullet and get there v3 package since tax times coming up.
New wheels finally fitted. Had to raise the rear 50mm so they could fit. ROH Modena 18x10 +15 with 295 semis. Next I will have get the arches flared out because they sit a bit outside the guard. Don't no if I should keep them white or get them sprayed black.
Haha yeh I think some over fenders will have to be used. My panel beater is gunn try pump the guards out as much as he can first. They sit about 30mm outside the guards. As for ride height I will be coming down just have to wait until the guard are flared as the rear guard sits on the tyre if a go any lower. Haven't really had a chance to play around with my bc cooler era yet.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
