R32 Gts+t Daily/street
Over two years of ownership I thought I'd make a build thread as i don't have enough procrastination in my life as it is.
up until this car I hadn't owned a car more than 6 months before selling it due to being bored of it or finding something else.
Originally bought this car back in November 2012 as a means for a quick profit. The plan being to fix the little problems, swap the wheels and sell it.
However as with most thing in life it did not go to plan...
This is how it was when i bought it
coilovers with chopped springs
1/2 turbo converted
lenso D1r 18x11.5 +12 with 235/40/18
Horrible interior missing parts.
First thing to go was the enormous wheels which just were not to my taste and did not suit the car in my opinion. in the mean time i put the lenso on my trike haha
Bought some old school work wheels for $70 to roll on while I sold the lensos and bought another set. also put some stock struts with lowered springs in.
Swapped the lensos for a few sets of wheels and cash my way. Included in the swapped sets was a set of R32 GTR rims
Due to the excessive guard rolling that had been required to “fit” the 18’s and the ill-fitting +30mm vented fiberglass guards the gtr wheels sat a fair way inside. which is kinda funny on 4 door
here is where i will leave it for the first post and will steadily update to present day over the next weeks
I decided the car was much too quiet and bought a set of drift pipes for it.
This hung very low and came up underneath the fuel tank. Buuut sounded the business.
Picked up a front lip from a type S R32 and tested it on my Type M bar. It “fit” bar the gap in the middle.
There is a point in which having a front lip is not practical. I found that point…
As I wanted to start modding it and getting it to run right I went and bought used universal FMIC kit. It was fitted to an RB20det R31 so I figured it would fit.
I found out why it was running so terrible. The motor had stock RB20DE injectors and ECU with a turbo bolted. Basically as soon as it hit 3psi of boost it would pull timing and drop in to limp mode. So I sourced a set of RB20DET injectors + ‘tuned’ ecu from a cefiro
Edited by CRSKmD
  • Like 1
not sure if anybody cares but im going to keep going with this. :wave:
I got stuck three wheeling and thought the only really solution is a 2way Nismo LSD. while fititng it inoticed my rear sway bar was missing entirely and fitted up a GTR one.
BOY did that make a difference! open diff +no sway bar -> tight 2 way and GTR sway bar.
some spacers where bought to fill out the guards.
13819_10151631393954896_1420058247_n_zps
307592_10151630877614896_922887527_n_zps
I found a Type M 2 door interior for a price that was to good to pass. fitted the seats, dash center console and sold the rest. while i was at it i replaced all the speakers and ran fresh wiring.
AJD 2013
i entered All japan day for the first time which was a fantastic experience which i recommend to anybody who hasn't done anything similar.
Here few pictures from he day below.
577968_4990015422632_12169396_n_zps7a096
181074_451472474921249_917299058_n_zps83
71992_388594297915056_945219255_n_zps672
S13 bootlip (Origin?)
New exhaust. An old AM performance build that solomon had on his 32 years back. this exhaust is a bit of a broad minded person and has been on many R32's
centre varex (cut and shut for ground cleance) stainless 3" then out to Ti tips
1899013_10152661012099896_816189490_n_zp
Cracked headlight so bought a pair of projectors and blacked them out and installed some jaycar HIDs
Also fitted some orange indicators while i was at it.
Blew up rb20 turbo and figured that the one thing my untuned NA motor needed was a bigger turbo. so i found an RB25 neo (OP6) and fitted that up. Around the same time i also installed a Front Facing Plenum.
Yes it looks horrible and messy here. Fear not as I cleaned it up down the track but that how it sat for a while.
As awesome as it was having cheap HID's in factory projectors not designed for them. the light output was atrocious and it had some seriously bad defractions going on.
I upgraded the projectors to (morimoto mini) Bi-Xenons from Loudz Creations and I also fitted some “demon eyes” for added wank factor.
Finished product:
920019_10152791850379896_863760709171190
Loose guide: (if anyone is more interested feel free to contact me with any questions)
i picked up another pair of factory projector headlights so my car did no ahve to be off the road for any length of time.
remove glass lens. i used a heatgun as death was not worth using the oven.
unscrew and pop out shroud
side by side shot of the factory and the new ones. they are smaller but specifically designed for HID's (curvature for focus etc). note the clearer glass
clearly they are not going to just bolt in. i cut the bracket off the factory ones so that i could retain the factory adjustments
i digged the blacked outlook for my car so i did the same again. (light sand, plastic adhesion primer, high temp satin black). test fitted new projector in hole.
"Demon eyes"
dissassembled the new projectors and stuck some cree LEDs behind in a ring pointing inwards. sequred with high temp copper silicon (gets hot when HIDS running)
test photo of leds on
re assembled lights: to attach the projector to the OEM bracket i sued some electrical standoffs and some simple brackets bad from scrap alloy
  • Like 1
Headlights look awesome.
How much power did you make with the op6?
Cheers mate. Light output is phenomenal as well.
Pre tune I made about 175kw. Post tune I made 206kw.
I still have a ways of updates to go until I'm up to current day
Dropped into Jaustech for a checkup and they told me that my rotors where below minimum thickness and one was infact warped!
I figured if i ahve to replace them i might aswell upgrade. I decided on going to 324mm (R33 Brembo size) rotors and a caliper adapter to run the 4 pots. this plan also means i can drop in the R33 Bremo's down the line if i desire.
As much as i liked the GTR wheels, 16" was not going to be able to clear the new brake setup so i began the hunt for a new set of wheels.
What i decided on was a set of Advan AVS model T7's in a 17x9 +22 all around. i picked these up in...well used...condition from Stewy.
Basically all of the wheels were like this to some extent.
fixed and primed
colour coat. actually really digged the matte look and almost left it there.
first coat of clear
clear done
close up shot. hard to see here but tis gunmetal with slight blue pearl. finish isnt perfect but i was more than happy with them
316_zps86021761.jpg.
fitted up some scrappies to get me rolling
This depleted my money for a while so brakes had to wait.
All Japan Day 2014
1957950_1429340673973785_212956278_o_zps
1962794_10152023950275945_1234338005_n_z
1932511_537106393069820_1559260216_o_zps
1185428_582857388449794_1617785896_n_zps
1781902_582857418449791_529582016_n_zps1
1655669_644869378916414_137874043_o_zps8
  • Like 1
Brake upgrade time.
finally had to justify changing to 17" rims and follow through with the brakes.
stocks
upgrade goodies. decided on some DBA T3 "club Spec" rotors and bendix ultimate pads(good balance between performance noise and dust on a daily driven car in my opinion)
rotor comparison
cleaned up and painted rotors I used metalcast paint. this took forever due to the 25 + years of brake dust!
gently sanded back to basecoat to make the nissan logo pop a bit more.
fitted up with caliper adapter. as you can see not all of the rotor surface is used but the extra leverage it gets and the better cooling made a noticable difference.
wheel on
side by side comparison
10173486_10152786974654896_759884142_n_z
full car side shot
Edited by CRSKmD
  • Like 2
As much as I always stood by my Type M bar and said that GTR front bar's only belong on GTR's a good deal came up and it is hard to deny that the GTR bar just looks better.
The bar had some damage and the bar was Bayside Blue (which my car was not).
However it matched close enough and look great in my opinion.
side by side with mates 2 door with FiberGross GTR (ish) bar
Time for my very first trackday.
I remember the first thing my dad said when i told him my intentions " alright, but be prepared to bring it back on a trailer."
I signed up for Drift Techniques out at Tailem Bend.
skidrims fitted. fluro represent!
10321741_321169404706746_894724443299753
not much ground clearance with the skidrims on...
10321626_321169611373392_881891905481801
checking for tyre wear
with an instructor int he car working on tight cone work
10368818_321169371373416_893030914058683
started too get it
10355466_321169678040052_262785019039447
10718051_669684809767051_1777802758_o_zp
as dad predicted on the trailer to take it home. thankfully i had some awesome mates with even worse luck willing to take my car back for me.
Managed to do some gearbox damage
10329191_10152953945879896_6825765926296
Here is what came out of the sump plug when i dropped the gearbox oil. all in all i dont regret the day and the damage even though my day was over my 11am. I learnt a bit and the damnage just meant an excuse for an upgrade...
  • Like 1
    • Hey lads, going to be removing the front CV's from the stagea (1999, series 2 rs4 auto), as the inner boots are shot on both, and since I'll be replacing the coilovers to a new/ish set of bilsteins, thank you SK, might as well do this too while I'm at it. Ive left this for way too long, atleast a year now, but no sounds yet so I think the joint is still okay. Anyhows, I am looking for a decent shop in Sydney who is decent, and wont charge an arm and a leg for it. Any recommendations? cheers TIA
    • Awesome stuff. I should sell my R32 and get a V37 RedSport haha. Looking forward to this build.
    • So, first things first, it's had a service for all fluids (2x coolant as it has air/water heat exchangers instead of air/air), new air filters (they were terrible, and one was pinched when installed by NIssan's "technician"). Also, both the boot and bonnet gas struts were shot, so ebay sorted some new ones, the jack handle kept me alive for the first service It needs tyres (more to come on that...) and the brakes are horribly grabby, looks like they've been badly glazed sitting around in Sydney traffic. On the bright side there are no obvious leaks and it runs well. The car goes well with 300kw (stock, claimed, I'll put it on a dyno soon), does good skids and handles reasonably well eg in long medium g corners. It is no cruiser like the Fuga though and is noticeably jiggly on the average (poor) rural road and terrible on corrugated dirt.  I'll get some road/race shocks in it shortly which should help.
    • So, for those following along at home, I've had the R32 up on stands for a while since a minor incident in the last rally, which required a new rear quarter panel to be welded in after the car had been (pretty much) put back square again. The problem is of course, that some R32 GTR stuff is simply not available (eg front guards) and other things are either expensive (second hand) or very expensive (nismo heritage).   In the end I've decided to try out a v37 with some track days, hill climbs etc before going ahead with modifying it for race/rally like the old GTR. To do so I've picked up an ADM Infiniti Q50 Red Sport, rather than a JDM car which offers much better value but might lead to complexities when I discuss spec with the production racing guys. In the meantime it will be my daily (well, more like weekly) driver, mostly highway use to Canberra or Sydney. BTW yes, I did notice it is auto-only, and yes I did know the Z comes with the same motor in manual. Big issue with the Z for me is that it is unlikely I can meet the new rally cage clearance requirements in that chassis so I've gone the 4 door/auto route The colour isn't great for rural lyf, and neither is having a sunroof for racing, but the Q50 market is small and it is what it is. Also...can't say I really like the shape much either, the front is OK but from the rear it is a dead ringer for a mazda 6
    • Ahh yes looks like I’m playing with a new cock on the weekends. Thanks for the information @soviet_merlin I’ll search for it later on and try to get it shipped. Looks like it won’t happen this weekend regardless. But the coolant looks fine so far (no floaties of concern). And waiting another week will slow down my money hole 😂
