R32 Sedan - Grip and Drift (have my cake and eat it too build)
11 minutes ago, joshuaho96 said:
Curious to know what others think of this, in my head this doesn't quite make sense. I'm thinking the explanation is more like the RB25 can keep the turbo spooled for a wider powerband so more power on average -> more heat to dissipate. Everything else kind of seems like a 2nd or 3rd order effect that wouldn't make a 30+C delta in oil temps.
open to other reasons. and i think both sides are true. the RB20 would keep making more power to redline and when graphed over the turbo map it was right in the middle. However, on the 25 it falls over at ~6.5k ish. but comes on sooner so.
Other points that would play a part:
 - The RB25 has a lower redline and revs up slower
 - on full boost from 3700-7250 (3550rpm range)
 - OEM rad shroud and oil cooler in free air with loose ducting
 - The RB20 had a higher redline and reved faster
 - on full boost from 4500-8250 (3750rpm range)
- no rad shroud and oil cooler between intercooler and rad
 - a few years of seat time??
^^^This, you would be amazed how much more load you put on a car when confident and experienced.
More 100% throttle in a higher gear and using the car for longer periods. Drifting also is hard on cooling systems as general not getting airflow over the front directly.
I drive a mates 350z and I use third gear (less rpm) more and I can do longer sessions where he uses second bangs off limiter and only gets say 30% less seat time before car gets hot.
Drifting yeah not surprising. but 2.5 laps at mallala on a grip circuit day 25°?
Thats a problem, I think your plans for cooling system will sort it out. I went through similar issues with the sil80 and the ducting is what sorted it out. Try some coreflute(sign board material) to make up temporary ducting to trial it.
https://www.bunnings.com.au/tunnelcore-1200-x-900-x-3mm-black-double-wall-pp-flute-board_p0488078
  • Like 1
yeah hoping to duct at least the intercooler/radiator before the next grip event if not the oil/pws coolers too.
corflute is a great idea.
  • Thanks 1
  • 4 weeks later...
New radiator and oil cooler have arrived
obligatory comparison shot
taking car of some small easy gaps first before I tackle some ducting. Just used some adhesive foam with a heat rating to 150C to fill this little gap air may take to bypass the radiator.
Oil cooler comparison
  • Like 2
Got the fiancé onboard to make a intake heatshield. I am still skeptical how much benefit this will really give on a turbo car but i guess colder air in should be colder air out.
  • Like 2
Posted (edited)
Unfortunately the new oil cooler did not quiet clear the intercooler pipes to fit inside the drivers side guard where I intended. So it was back to in between the intercooler and the AC condenser.
While this may not be great for adding heat it is much safer especially for drift and my affinity for sending it into tyre stacks
Mounted up the water sprayers. Because I originally intended for the oil cooler to be mounted else where I bought a single nozzle sprayer to go with it. Figured I should still use it so I mounted it between the intercooler and the oil cooler.
Edited by CRSKmD
typo
  • Like 3
Next up was from CAD🙃 work for making up some ducting.
Transferred the template to some scrap 3mm aluminum I picked up and added some pinchweld with gasket to help with  sealing.
The same process was used to cover the other large gaps.
Made a bracket up to hold the water sprayer tanks (5L each for 10L total).
The pump for the water sprayers was installed where the battery used to be, which was relocated to the left hand side.
While I was cleaning things up I decided to remake the aircup system mount.
Before: which made more sense when i had a full boot trim and sub/amps
After
The boot feels and is likely more balanced now.
  • Like 2
Nice. I just use black corflute for these. Light, cheap, disposable if necessary.
yeah that was my plan but then the scraps of 3mm aluminum were free
Half your luck. I just had to buy a piece of 4mm ally to make a flange because I couldn't find any suitable scrap in the places I spend time!
Hard to say exactly which cooling upgrade had the most effect but the combined outcome allowed me to do 8 hot laps at Mallala back to back on a 22C day without me seeing the oil temp exceeding 106C or water 95C without the water sprayers being on.
I have not checked the data logs yet to confirm the max temps, but it was certainly a success.
  • Like 2
  • 2 months later...
An issue I had with my current setup was no way to adjust front camber to a point I needed it while also not negatively effecting Caster. Thanks to the way the R32 front end was designed if you lengthen the Front upper camber arm (FUCA) to reduce camber you also reduce caster. This also resulted with the wheel sitting forward in the guard where 7.5° caster was but only actually having 6.5°.
In order to have the caster back where I needed it to be I had to shorten the FUCA which of course added negative camber to the tune of -4.8° which was a little extreme for a grip/street alignment.
The solution was to shorten the Lower Control Arm (LCA) by going back to a stock R32 one. The risk here was what if it was too short and caused issue with the drift alignment. So instead I "had" to opt for a custom adjustable LCA.
Once again Stewy from Acostal was able to accommodate my have my cake and eat it too build by making some shortened 210 series arms. As long as I was willing to help with some of the die grinding on them.
undefined
R33 LCA + Acostal 110 Caster arm (both for sale 😘) vs new Acostal 210 full LCA/Caster arm.
Close up of new arm. Adjustments include LCA length, Caster, Bump stop and Roll center correction.
New arm installed and sway bar dropped
Roughly setup by eye in the +5° Ackerman setting
May have measured camber wrong as once checked on level ground with my phone it looks like -5° Camber and I will hopefully sort it out on the aligner. thankfully I now have on car adjustable camber.
You wouldn't know it but the front wheel here has effective specs of 17x9 -10!
  • Like 2
Unfortunately we ended up not quite getting to where I wanted alignment wise. Ideally I was targeting -3.5 to -3.8 camber as a good compromise for drift/grip/street. But due to the combination of custom configuration custom parts and the relationship between caster and camber (as you reduce camber you also reduce caster) on R32 we ended up at:
Front
Camber -4.5°
Caster +7°
Toe -4mm toe out each side. -8mm total
Rear
Camber -1.5°
Toe 2mm in each side 4mm total in
Perfect for drift but will be a touch too much camber for circuit. Thankfully the arms being modular means a change to one simple bracket will give me the adjustment I need to get to -3.7° camber and keep the caster at 7°.
Woah! Can't believe I stumbled into this thread - I've had my R32 sedan about as long as you've had yours, and looks like we have both done similar mods to try to get past these RB cooling issues. Such a rad car, love what you've done to it!
  • Like 1
    • Did a little bit on the V37 today. I bought this LED kit out of the US https://www.ebay.com.au/itm/125953603618. Best I could find online but didn't look great, in the end the quality was pretty much right and it did come with locations for each light including rear number plate and a few spares. The factory owners' manual was also useful with information on where to pop each light out without damage. I prefer the LED look as I use it daily including at night and the LEDs are both brighter and the white light is easier to read with. Vanity mirror comparison, LEDs just look more modern The glove box was the only difficult one (and the only one that was previously blown.....), steps were Open glovebox 50% but not fully open Push up on bottom of the box to unclip it on both side, not screws or pins to remove Remove the top stays at an angle, right side then left, because.... Before dropping the glovebox totally, remove soft close clip on left Then, remove 7 screws to release the glovebox surround Twist the globe holder anti clock to release it from the surround In this case, the LED globe supplied was wider than factory and did not fit, so I ground down each side about 1mm then inserted it Last trick, start engine to check the LED polarity is correct, the globe only operates when the engine is running (whether the box is open or closed) I also moved the 4G booster and wifi across from the Fuga, a little frustrating as I could not find a good Accessories ACC source anywhere in the boot so I'll run a wire from the cabin next time I get a chance. Also, unlike the Fuga the external antenna wire does not quite fit between the rear windscreen and the body so I think I'll have to drill a hole in the roof to mount it. Probably not that interesting for most people so I'll just post once complete
    • Pretty sure I could do but it would need to be exported and reimported as the current import approval is race only. But in practice there are plenty of other practical reasons it can't be a road car despite their potential value these days like stripped interior looms, cage to cut out etc Nah, no mods to it other than updating the roll age to current regs. It makes about 350 (laggy) kilowatts on the N1s at 18psi which is enough to push it around the place
    • This is it, folks! Our final event of the year... The big one, you all know and love - Putty Road! It goes without saying, but this is the biggest cruise in our calendar each year! A nice long drive, with a hearty pub feed at the end! Do you need much more enticing than that!?!? So make sure you wash the car, get your cameras out, block out the calendar, and get ready! We know you're all as excited as we are, so make sure you lock in the details and date below: Date: Sunday 8th December 2024 Meet Location: Corner Windsor Road and Groves Avenue McDonald's / KFC (3 Groves Avenue, Mulgrave) Meet Time: Meet at 9:00am for a 9:30am departure Destination: The Royal Hotel, Singleton (84 George St, Singleton) Map: https://tinyurl.com/saunsw-puttyrd Itinerary: We will meet at McDonald's / KFC on Windsor road and from there will head onto Putty Road. There will be a break at the Grey Gum Cafe (8679 Putty Rd, Putty) which we should reach at approximately 11:30am. For all the Newcastle folks this will be a good point to join up. From here we will continue on to Singleton for lunch. Please remember to fill up prior to heading onto Putty Road. There will not be a fuel stop until Singleton. To those running on E85, Freedom Fuel (old United) at Vineyard on Windsor Road has started selling there. At Singleton there is a range of servo's available including BP, Shell and Caltex. There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Back by popular demand - we're lining up another Old Pac Run! Get your cars ready for one of the best night runs on the calendar! So without any ado whatsoever, here are the details for you to save: Date: Saturday 23rd November 2024 Meet Location: Cowan Truck Stop (Pacific Motorway - Refer to Map) Meet Time: Meet at 7:30pm for a 8:00pm departure Destination: Gosford McDonald's (65 Pacific Highway, Gosford West) Map: https://tinyurl.com/saunsw-oldpac Definitely an easy one for this cruise, meet at Cowan Truck Stop and jump straight onto Old Pacific Highway! Final stop at McDonald's which has plenty of parking all around. Please be mindful of the added police presence lately so best behaviour is expected! There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAU:NSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Back to our newest location for our Sunday morning coffee catchups! As always, this is the best place to meet up with the SAUNSW fam for a coffee, bite to eat, and a chat! So what are you waiting for? Block out the calendar, set your alarm in the morning, and come down to hang out with the SAUNSW fam! Date: Sunday 10th November Meet Location: Baybreeze Cafe - 2 Wellington Street, Sans Souci (entry via Plimsoll Street) Meet Time: Meet at 8:00am Map: https://tinyurl.com/sausundaysession-baybreeze This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
