R32 Sedan - Grip and Drift (have my cake and eat it too build)
Dropped the 32 off to have a custom Half cage (3/4 cage?) fabricated will update once complete.
Looking into harnesses now. I like the "yashio factory" ones purely because they are pink and look to meet all specs.
But open to opinions
Look at FIA rated/certified ones.
5/6 point, cam lock and good buckles. I've used sparco, MVP/Raceworks, velo.
Also look at Hans specific 2 to 3 inch belts if using a Hans.
Raceworks will do fancy colours too
  • Like 1
The yashio ones are FIA but I’ll take a look at velo and raceworks too as I have seen they do pink in some options.
only issue is my bride Digo R seat does not have a spot for the 5th point belt to come through the base cushion. Don’t really want to change the seats just yet. How will would a 5point work with that style seat
Not sure what the purpose is for a harness, but a 4 point harness is basically the same safety-wise as lap sash; you still run the major issue of submarining under the belt in a big one. 5 and/or 6 point belts require a hole in the cushion and seat base and mounts in a specific area under the seat
The Car is still street registered and driven. The main use of the car is still just circuit days (time attack not door to door), Drifting (mild tandem-ing) and the occasional weekend drive. May do the occasional hill climb or road rally in future.
I almost always have passengers in the car at least at some point during a track day. So getting a cage for safety was the primary reason. I also did not want to run harnesses without at least a harness bar and cage. Another reason was that moving up a class for DSA days requires a cage.
I have seen people add a slot in the base cushion to accommodate the 5th/6th belts which i could be willing to do.
Eventually I will probably swap of the Brides for Velo GP90s etc which already suited. But financially wont be able to do that at the same time as the cage/harnesses.
Yeah you should really holesaw a hole into the seat base and cut a slit into the cushion, and buy or 5 or 6 point one. 4 point is really not safe for track use and probably not CAMS rules compliant anyway. For the mountings there are diagrams in the CAMS manual about where the 5th and/or 6th point need to be, and you can buy or make compliant reinforcing plates for the nuts like this:
https://www.vsport.com.au/grayston-eye-bolt-back-plate-fia-approved
Depending on the exact Sprints being ran, there may end up being a need for HANS, but from memory MotorSport Australia only need that currently at state level upwards, but I foresee them lowering that in the coming years, may as well plan for HANS capable setup.
Posted (edited)
I have purchased a pair of FIA certified 6 point harness that is HANs compatible and will look into buying some appropriate seats like a Velo GP90 that already have the sub-belt slot rather than cutting up my genuine Bride Digo R's
Edited by CRSKmD
typo
  • Like 1
  • 3 weeks later...
Cage is well underway so here is some progress pics
J18 Dual occupant spec with X-brace  through main hoop so i can still stack tools/jerry cans in the back seat area
Removeable door bars
some weld close ups and the fasteners used for the removable bars
All welded up ready for powder coating
  • Like 4
Cage has come back from powdercoating. Colour is "Dormant Purple."
Rested the door bars into the car for now just to see how the colour looked. Cutting carpet, install and trimming to come
  • Like 6
  • PranK changed the title to R32 Sedan - Grip and Drift (have my cake and eat it too build)
Love the colour, cage looks great mate!
  • Like 1
Th 3/4 cage is bolted in with carpet cut. I plan to retrim the back seat area to have it feeling complete/GT3 vibes soon. For the rear door cards I'm using some poor condition factory door cards. I will cut up and make flat cards from to clear the cage.
  • Like 1
    • Oooohhh man did not bloody know that, that's amazing thanks heaps for sharing mate, bookmarked it!
    • In case you haven't come across it, there's also https://nissan.epc-data.com/ Go by VIN or drill down into your specific model and year and it'll have references for pretty much all the OEM parts. In very similar diagrams. Linked against amayama as well for ordering. Though they can be a bit slow and can be better to search around to get the parts locally.
    • Just in case anyone finds this in the future, here's a diagram sent to me by Nissan to identify these hoses. I ended up finding them through EFI Solutions though because Nissan reckons they need to order it from Japan, with a total cost of approx $110 inc. So it as cheaper with EFI anyway. https://www.efisolutions.com.au/blow-by-hose-rb25det-r33-wc34-c34-c35 https://www.efisolutions.com.au/blow-by-rocker-cover-hose-rb25-r33-wc34-c34-c35
    • This is an older post of mine but I just thought I should update it and explain what the problem was. Long story short the friction plates were below their service limit. New they are around 4mm, and service limit is (according to OSG) 3.5mm In addition the crank seal gasket wasn't sealing 100% anymore and that led to an oily clutch. Not sure what came first and why the clutch was worn after just 10,000km .. but all good now. OSG refresh kit via Nengun
    • My r34 GTT auto transmission is slowly letting go, slipping every now and again, tiptronic deciding to not keep it in 1st / 2nd when flooring it, taking longer to shift so I’m going going flush it and replace the filter and hope it lasts a bit longer.    I’ve got 10L of Penrite ATF FS at home and I’m going to use it for it unless ye completely recommend against it.  Penrite list it as compatible. i understand I should be using Castro Transzmax however it’s quite expensive and I already have 10L of the ATF fs. Has anyone here used atf fs for there got or heard of anyone? Or am I silly for even considering anything other then Castrol  Thanks for your advice
