R32 Sedan - Grip and Drift (have my cake and eat it too build)
Dropped the 32 off to have a custom Half cage (3/4 cage?) fabricated will update once complete.
Looking into harnesses now. I like the "yashio factory" ones purely because they are pink and look to meet all specs.
But open to opinions
Look at FIA rated/certified ones.
5/6 point, cam lock and good buckles. I've used sparco, MVP/Raceworks, velo.
Also look at Hans specific 2 to 3 inch belts if using a Hans.
Raceworks will do fancy colours too
  • Like 1
The yashio ones are FIA but I’ll take a look at velo and raceworks too as I have seen they do pink in some options.
only issue is my bride Digo R seat does not have a spot for the 5th point belt to come through the base cushion. Don’t really want to change the seats just yet. How will would a 5point work with that style seat
Not sure what the purpose is for a harness, but a 4 point harness is basically the same safety-wise as lap sash; you still run the major issue of submarining under the belt in a big one. 5 and/or 6 point belts require a hole in the cushion and seat base and mounts in a specific area under the seat
The Car is still street registered and driven. The main use of the car is still just circuit days (time attack not door to door), Drifting (mild tandem-ing) and the occasional weekend drive. May do the occasional hill climb or road rally in future.
I almost always have passengers in the car at least at some point during a track day. So getting a cage for safety was the primary reason. I also did not want to run harnesses without at least a harness bar and cage. Another reason was that moving up a class for DSA days requires a cage.
I have seen people add a slot in the base cushion to accommodate the 5th/6th belts which i could be willing to do.
Eventually I will probably swap of the Brides for Velo GP90s etc which already suited. But financially wont be able to do that at the same time as the cage/harnesses.
Yeah you should really holesaw a hole into the seat base and cut a slit into the cushion, and buy or 5 or 6 point one. 4 point is really not safe for track use and probably not CAMS rules compliant anyway. For the mountings there are diagrams in the CAMS manual about where the 5th and/or 6th point need to be, and you can buy or make compliant reinforcing plates for the nuts like this:
https://www.vsport.com.au/grayston-eye-bolt-back-plate-fia-approved
Depending on the exact Sprints being ran, there may end up being a need for HANS, but from memory MotorSport Australia only need that currently at state level upwards, but I foresee them lowering that in the coming years, may as well plan for HANS capable setup.
Posted (edited)
I have purchased a pair of FIA certified 6 point harness that is HANs compatible and will look into buying some appropriate seats like a Velo GP90 that already have the sub-belt slot rather than cutting up my genuine Bride Digo R's
Edited by CRSKmD
typo
  • Like 1
  • 3 weeks later...
Cage is well underway so here is some progress pics
J18 Dual occupant spec with X-brace  through main hoop so i can still stack tools/jerry cans in the back seat area
Removeable door bars
some weld close ups and the fasteners used for the removable bars
All welded up ready for powder coating
  • Like 4
Cage has come back from powdercoating. Colour is "Dormant Purple."
Rested the door bars into the car for now just to see how the colour looked. Cutting carpet, install and trimming to come
  • Like 6
  • PranK changed the title to R32 Sedan - Grip and Drift (have my cake and eat it too build)
Love the colour, cage looks great mate!
  • Like 1
Th 3/4 cage is bolted in with carpet cut. I plan to retrim the back seat area to have it feeling complete/GT3 vibes soon. For the rear door cards I'm using some poor condition factory door cards. I will cut up and make flat cards from to clear the cage.
  • Like 1
On 6/28/2024 at 9:34 AM, CRSKmD said:
Unfortunately we ended up not quite getting to where I wanted alignment wise. Ideally I was targeting -3.5 to -3.8 camber as a good compromise for drift/grip/street. But due to the combination of custom configuration custom parts and the relationship between caster and camber (as you reduce camber you also reduce caster) on R32 we ended up at:
Front
Camber -4.5°
Caster +7°
Toe -4mm toe out each side. -8mm total
Rear
Camber -1.5°
Toe 2mm in each side 4mm total in
Perfect for drift but will be a touch too much camber for circuit. Thankfully the arms being modular means a change to one simple bracket will give me the adjustment I need to get to -3.7° camber and keep the caster at 7°.
Acostal came through with a new bracket which should free up some adjustment arm and hit my target of -3.7° camber and 7° caster. (old black, New silver)
fitted up and you can see how much shorter it makes the relative length of the caster rod as well as swinging it slightly to free up some misalignment in the bearing
with Caster maxed out short this is how the wheel sits on the car in the air
While I was at it, I pulled the wheels off the car to inspect the suspension and noticed this lovely gash. A pity becasue these tyres, while on wear bars, would have had at least one more dry grip day in them. Have a set of AD09 to try out next which I expect will be slower than the CR-s or AR-1 were but better in the rain with a longer life?
Edited by CRSKmD
    • Thanks mate yeop be good ! Understand the kid thing for sure lucky mines a bit older and I can bring him over etc he gets treated like a rockstar 😁 go the RB   yeop wont be doing this forever prob so why not 100% everyones always been good but going back this year was different and more interaction and def more support Def thought about changing uprights etc waiting for @Komdotkomto sort out whats needed for those and do the r & d haha  but yeah hard thing for gtst nothing direct fit as all made for GTR which is slightly diff but moving to the r35 gtr bearing will be big improvement - its just budget allocation as its a $10K to $30K exercise dependent on how mild or wild you go and seems something always comes up - ontop of the crazy travel / racing
    • Great write up. Always good to record everything to look back in the future and reminisce. How good is the motorsport community with helping out when needed.  Should be pretty proud of the result you achieved for the little amount of laps you've done there. Also good you have the drive to do better too ,I'm sure a 1.29 will happen next year.  You thought about a front end upgrade? New upright and arms with better geometry also allow a better bearing your not replacing every time.
    • Cracker read mate! Would be nice to meet you soon, probably when the kids are a bit older and I'll take them along to see the world's fastest 4 door skyline
    • OK WTAC '24 adventures - dont know if anyone wants to hear it past whats been put out already but hey I'll put some of it out anyway and try give some insight   Summary : end result - 6th open class and 1.31.1 lap   How'd we get that   Following the above after Aus Time Attack at Winton and driving the car up to Sydney to store the rb2.8 went in so got to fly over to Sydney the Monday before the event     The car was with Greg at Sydney Composites workshop - we got straight to work that arvo changing out the front wheel bearings as they flog out allll the time.   A new bonnet was being made and my goodness its nice !  also new bigger canards were put on as I was the first one to trial the new canards and after testing from others bigger basically proved to be better rather than my initial cut down version.   We also did ride height changes and setup was there till 1am Wed morning but got it all done     A big focus this year was to get me some seat time on SMP - laps for me = good so has an extra prac Wed morning to roll around so up at 6am to track     Basically 2 quick sessions and 3 'hot laps' we quickly worked out that the custom red / golds  MCA's I had in werent valved strong enough to hold up all the new aero at these speeds, we suspected at Winton but were hoping... but alas nope. Also the tyres I had on from Winton were gone and just down right dangerous haha   So... some appropriately valved MCA golds were sources from Canberra and driven up straight to the track for me to borrow and retro fitted with my current stuff and some better used tyres put on from Xtreme.     Got into the arvo where I had to take more prac spot so took it - we got 2 x goes at a lap but the setup was wrong and was porposing like crazy so aborted each one but we got it sorted correctly after but didnt get to go out again   WTAC official prac Thurs   Did 3 sessions of 1 lap each time no power - suspension better few tweeks here and there and got to get a little bit of a groove back all seemed OK   We found the car getting back to some understeer because we still had the old rear suspension in and it couldnt handle the aero load but had no options so had to work around it ... it ended up scraping the rear diffuser that sits quite away off the ground that how much it was !   WTAC - Competition day 1     Morning Session - usually the best - wound it up had a crack was good but safe and not the max from a push p.o.v 1.31.6   The wind then picked up as did temp went out just for a lap on no power for second session did a solid 1.33 totally sat out the last session as no point due to track conditions   WTAC - Competition day 2   Morning session - full send !  - ran it hard down the front straight as I got to T1 turn in car faulted and switched off - tried to do another lap after resetting tyre pressures and fuel but was not working properly and got blocked and then had red flag anyway haha - bad   Long story short - the balancer had gone and as well took the DBW with it     Organized chaos ensued - between my team - Dahtones and Herman and just about everyone else we got everything needed and a new 1500 ATI put on - luckily thee was a Bosch motorsport stand in trader ally and they let us take the DBW they had on display to put on my car !  legends   So at this point we've only done 1 real lap , missed the good session in the morning missed session 2   Pit walk was upon us and is always so busy but great and met @soviet_merlin and others we also try to get as many kids in the car for fun and photos as possible + meet people     Session  3 - last one - wind was up, track was horrible didn't matter had to go - launched it as good a I could. We changed setup to leave the car in 5th gear into front straight so I didnt have to change down and worked well just held it flat max powas and max rpm - 282 kmph and 217kph around T1 (this has to improve alot )was up 1.2 secs into T8 despite mistakes and as previously said tyres just started going to mush - I couldnt get it around T8 properly lost most of my time picked more up with last 3 corners ended up 5.5 tenths up on previous good lap for new PB but missed out on top 5 by 6 tenths Still not my best lap I shouldve had it to make top 5 but didnt... thats racing     A positive takeaway from an effing tough go at it this year - netting only 2 x hotlaps is both my 1.31 laps combined optimally gave a 1.285 - now I know I'll never be perfect but with a 2.6 sec difference - that means its there it just comes down to consistency to bring that down into an achievable 1.29ish   Our best endeavors to have good seat time and a well sorted car illuded us this year but still got it done as best we could   Good mate made me take a pit pic in front of the car which I look at now and is good as you just dont know I might not be back, or I might !     And then after watching the wild Top 5 shoot out you get to pack up starting at 9pm so pack it all up properly for long trip home   We had a sleep and then yeop ... a near 4 day drive back to Perth. Look I dont actually mind the drive - its not great but its not horrible - but the toll it takes on you after or before competition isnt optimal and neither is the time it takes to do - maybe another option but they are few and expensive I tell you what im basically an international and would be ALOT easier to compete at WTAC if I lived anyway but W.A 😆   All in all hard work, solid result on paper but even if I was still 6th I would've like to at least be in the 1.30s and as close as I was and maybe due to circumstance it still says a 1.31 - which isnt sh*t just not the best .... the W.A crew that comes with me is awesome, im appreciative of getting to work with some of the best on top of that with Brad and some help from the pro drivers, Xtreme and others   So back home back to it - full set of MCA golds going in now which was on the cards anyway and a new 'proper' race radiator to keep it cooler   See what comes up next to race at or in ... that I dont know
    • Acostal came through with a new bracket which should free up some adjustment arm and hit my target of -3.7° camber and 7° caster. (old black, New silver) fitted up and you can see how much shorter it makes the relative length of the caster rod as well as swinging it slightly to free up some misalignment in the bearing   with Caster maxed out short this is how the wheel sits on the car in the air While I was at it, I pulled the wheels off the car to inspect the suspension and noticed this lovely gash. A pity becasue these tyres, while on wear bars, would have had at least one more dry grip day in them. Have a set of AD09 to try out next which I expect will be slower than the CR-s or AR-1 were but better in the rain with a longer life?
