R32 Gts+t Daily/street
Got the new diff setup at 1110 Engineering and into the car.
decided i should really try and clean up the exhaust while i was at it so future leaks are easier to find and hopefully reduce the smell.
I also fixed up the varex wiring which had been not used for the last 4+ years. Turns out the varex had been slightly closed all this time
Bought some Acostal knuckles with custom Ackerman specs to better suit the use case of the car. These will go from stock (+20°) though to essentially parallel (0°).
Some other benefits are:
  • Change of KPI for less camber gain but with more static camber
  • LCA pushed lower from some correction
  • shorter steering arms for a faster ratio
VS. stock knuckle
test fit
The plan will be to get an alignment in the +20° position with the toe set for grip and street duties
Then another at +5° with more toe out.
This way i should be able to drive to the track then, for drift days, in 20 mins or less swap the ackerman position and adjust the toe (ideally in 0.5 turn increments) for drift.
I am also looking at moving the steering rack forwards 25mm. which will also effect ackerman but reduce chance of bind
  • Like 2
After years of avoiding it due to it effecting/reducing the ackerman and being potentially worse for grip. I finally have relocated my steering rack forwards. I picked up a spare crossmember so just in case i hate it i can revert back to stock position.
hopefully this will eliminate the binding at lock while drifting.
closer look
I used a engine support beam to hold everything up while i dropped the stock crossmember out the bottom. It all went pretty quickly but, of course, not without issue. In typical Nissan fashion the engine mount split, though only on the passenger side. It looks like heat from the turbo may have been a factor.
  • Like 1
Torque for sure helped pull it apart but I think the heat helped to perish the rubber. I replace both together in 2019 ish. The driver side is still supple and rubber feeling. The passenger one is much more dry and cracked.
eitherway slapping another oem style on in for now as I was able to grab one from a mate in reasonable condition. But may look into other mount styles in future.
14 minutes ago, DaymoR32 said:
i've got solid billet engfine mounts in mine, no vibrations at all. i was actually suprised when i saw them with how smooth the car feels.
Really!? I tried a billet gearbox mount back in the day and it lasted all of 5mins before i went to a harder rubber Nismo one. Thought it would be worse with motor mounts
Honestly, thats why i was suprised when i saw them!
did some eyeballing of where the current 285mm tie rods could get me and found they were ~15mm to short to get my drift alignment settings.
Found RE-844L which is meant to be 300.5mm long. Turns out the "ROADSAFE" version is 306mm long
bolt everything to check clearances in each setting.
Grip
"Drift"
pretty cool what one bolt and then some toe adjustment can do to hopefully mean i can drive to the track on a street/grip setting and reasonably quickly change it to a drift setting.
  • Like 2
25 minutes ago, Dose Pipe Sutututu said:
Very cool!
Just a question (besides extra lock, and reduction in camber ramping), what are the real differences between grip and drift mode?
so the knuckle changes to stock:
  • LCA pushed lower drop knuckle from some correction
  • use of 350z bolt on hubs which are easier to change and bigger/stronger
  • adjustable ackerman, in my case 0, 5, 15 and 20
so all of the above benefits/changes stay the same all that changes between my drift/grip setting is the ackerman and the toe.
As a starting point i'm trying out but will keep adjusting to find what works for me.
Grip:
Camber: -4°
toe: -2mm total
Caster: 7°
Ackerman: +20°
Drift:
Camber: -4°
toe: -8mm total
Caster: 7°
Ackerman: +5°
  • Like 1
@CRSKmD thanks for that!
Very cool insight for sure :)
I guess with drifting you want massive turn in, hence the toe out. Can't imagine how fun/not fun that would be driving to and from an event lol... the car would tramline all over the shop on our shitty Aussie roads.
yeah the the "inside wheel" becomes your "lead wheel" and the "outside wheel" becomes your "trailing wheel" so where they are loaded up and when is almost flipped
  • Like 1
  • 4 weeks later...
  • 2 months later...
After dealing with temp issues most track days with oil reaching 130°C *
(*oil temp sensor maxes out at 130°C)
I decided to look at upgrading the cooling system.
To start with i got two new oil temp sensors from Metric Motorsport, one to replace the existing one on the sandwich plate and one additonal sensor to place on the relocation block so i can see the temp delta and the effectiveness of the cooler. Though looking at oil flow direction I may need to get an inline -10AN fitting so the sensor can firmly be in the return path post cooler as the current position is on the hot side of the loop.
The plans for this upgrade:
- Bought a Koyorad to replace the old cooling pro ebay radiator i got in ~2013
- Larger oil cooler to replace the 10row trust core, 25-30 row if i can fit it
- Watersprayers
- Ducting
  • Like 1
2 hours ago, CRSKmD said:
- Ducting
This is key to any heat exchanger. Getting fresh air in and across the whole surface.
25 row oil cooler will be enough.
With old cooling pro radiator (fully ducted from front bar) and setrab 20 row oil cooler (open air) with thermostat (85C) on the rb25 (half grout filled) in s chassis.
93C Coolant Temp, Oil temp around 96 after 5 laps QR on a 30 degree day
The biggest cause of heat is the undersized turbo. With the same setup on the RB20 where the turbo sat in its efficiency range I’d never cross 100° oil temp. Now where it’s sitting outside I have seen manifold temps of 1200° according to the ceramic coaster when he looked at the car recently and have seen the exhaust housing glow red ¯\_(ツ)_/¯ .
But I am avoiding the snowball that will be changing out the turbo.
so fingers crossed all the above with better ducting will be the solution.
Curious to know what others think of this, in my head this doesn't quite make sense. I'm thinking the explanation is more like the RB25 can keep the turbo spooled for a wider powerband so more power on average -> more heat to dissipate. Everything else kind of seems like a 2nd or 3rd order effect that wouldn't make a 30+C delta in oil temps.
    • Gosh these bmw's are worse money pits than JDM's! I won't complain about my car anymore 😂
    • I'll just leave this quick tip here after reading your joys of getting the car in the air. It should take no more then 10 minutes to get the car safely up on stands.  So for the front, jack on the tow recovery points (marked in red). Put the jack stands under the lower control arm mounting point (marked in yellow). This photo is of a R34 GTR, however the process is the same. For the rear, jack under the diff (marked in red). Put the jack stands under the rear subframe or where the lower control arm mounting point (marked in yellow). Which point you use will depend on your stand, pick a nice stable point.  You've probably already read this but it's worth repeating. When jacking up the car or using stands, stay away from the chassis rails/pinch welds. Even the factory jack point, stay away from that too unless using a factory jack. I used those jack points for years without issue until I turned into an old man and bought a QuickJack lol.
    • And this is where the leak is happening: https://www.dropbox.com/scl/fi/7h1vlmg2j5aa7rksvsjc9/IMG_9982.jpeg?rlkey=d3bnpau5f615zmxqmca0llvr7&st=kquvdxvs&dl=0   Apologies but it seems adding an image from a link does not work when the images are in Dropbox.
    • Here are some pics from the auction: https://www.dropbox.com/scl/fi/gkbfaa7urogzhyzxtdgq4/4cd77e2d-e19f-45fb-80a0-f9a88fd7f51f.jpeg?rlkey=39p7xyvgr33kj0avcjry2v4ap&st=ncxmagj4&dl=0   https://www.dropbox.com/scl/fi/gkbfaa7urogzhyzxtdgq4/4cd77e2d-e19f-45fb-80a0-f9a88fd7f51f.jpeg?rlkey=39p7xyvgr33kj0avcjry2v4ap&st=ncxmagj4&dl=0
