RB25DET gearbox.
pickup a second had gearbox and got it checked over by 1110 Engineering.
Also got a manual tailshaft and got it cut, shut and balanced.
Don't believe what people tell you, from my experience no standard nissan gearbox crossmembers bolt rightup (tried the CA18,SR20,RB20,RB25 manual and auto varients of each +tried them all bother ways around) best i could get was 2/4
Took some measurements and went back to 1110 for him to weld my up a crossmember. (man i have to learn to weld someday).
size comparisons
Checked the clutch while the box was out still mint. (forgot to mention some time in 2013 i replaced the slipping HD clutch with a NPC carbonic cushioned button clutch + a slightly lightened flywheel)
which looked like this.
1379269_10152365474984896_726445543_n_zp
New intake time. i had rocked the stock airbox and intake for a while and liked the stealthiness of it but sometimes you just need some noise!
paid a friend to make me up a lobster intake.
by no means perfect but im was more than happy with the result and the resulting sound was great MASSIVE induction noise + VL turbo spec dose thanks to the missing BOV due to FFP.
save the "going to break your turbo blah blah" heard it before don't care. been running like this with no issues or boost spikes for 15,000kms and no shaftplay. plus if the turbo eventually goes it just means its time for a new/bigger setup
Nice to see someone else that likes the doze i had mine doing it for nearly two years and never had a issue. Don't know why you had issues with the gearbox cross member the standard r33 manual one bolted straight up and was exactly the same as my auto one.
- Don't know why you had issues with the gearbox cross member the standard r33 manual one bolted straight up and was exactly the same as my auto one.
might be because my chassis was auto NA factory? not sure but it all fitted int he end haha
Yeah I went from a auto it heaps better now haha. How do you find the cushion button on the street.
I daily mine in traffic. once you get used to the slight change in take off/driving style its so so easy. that said i also have a larger slave cylinder.
more track days RB25box in place this time.
10496155_680997495314879_463110353020804
gave me a chance to get a good feel for the car.
10551589_343669965790023_385450053719971
Turned out it was understeering atrociously. so after the track day was done and dusted i decided to look into what the cause might have been.
Before i could get to that though. this happened
luckily it ended up being a copshop visit for "incorrect wheel/tyre size fitted". before i headed down there i fitted stock suspension type m bar and some less pokey wheels plus made the exhaust quieter. I did want to give them any reason to direct me to regency ;)
after clearing the defect and putting parts back in i noticed my coilover spring rates were a bit out from what i expected/ordered.
6kg rear 12kg front...
fitted up 8kg fronts
i also changed the setup from hellaflush to hellafunctional. (eyebrow heights were 290F 295R. now they are 335F 330R)
Just for good measure and to aid the understeery issues i fitted up some 245/40/17 Goodride RS tyres as i had heard good thing and they were cheap.
The tyres were 225/40 F 235/45 R
then i got a wheel alignment with a fairly neutral front toe set.
all said and done this is how it ended up
before (still type m bar photo) and after.
Edited by CRSKmD
Lucky the cop incident didn't result in more problems!! I'm surprised the wheels were an issue, they don't really look like they poke?
Looks like she does a good skid anyway :P
Hope you get the understeer issue under control too
yeah haha
at the time i had almost 0 rear camber for tyre wear.
1653468_10152666432004896_1403485015_n%2
and the cop said "there was no room in the guard for anything and if i hit a pot hole the tyre would explode" :rolleyes:
Engine Bay cleanup and tune
As seen earlier in this thread i started a cleanup of the enginebay.
first i did FMIC and stock airbox. then FFP folowed by the Lobster welded intake.
part 2 of the clean up involved not making it look like poo.
closer shot. painted plenum and piping black new joiners and clamps. painted engine. NDR Fab lobster cold-side to replace the massive blue joiner.
Shot of Cold-side. note the bung to keep AAC working.
stilla ways to go such as surrounding wiring, paint the bay etc but realistically thats an engine outjob.
next came the basic supporting mods. Z32 AFM, R32 GTR injectors+resistor pack, Nistune. I had already put in a Profec B spec II earlier in the year.
11psi
RB25 neo
13psi (wasnt happy no matter what we did)
before 11psi and after 13psi on same sheet.
i just keep it on 11psi because the extra 5kw up top isnt really worth the extra 2psi haha, ceramic wheel and all.
overall pretty happy with the results considering the mod list. nice almost NA-ish power delivery
RB20DE+T
RB25 neo turbo (OP6)
Z32 AFM
R32 GTR injectors
FMIC
FFP (doesnt really do anything, same runner length etc)
turbo back 3"
Went to another track day and shredded tyres.
then the next one came around i decided to save some money and not enter.
Instead i went along with a mate and filmed the day. First video i have ever filmed/edited of cars.
Edited by CRSKmD
As its a street car i figured it was time to do some cosmetic mods.
Waaaay back in mid 2013 id picked up a set GTR guards needing minor repair. i stripped 90% of the paint off them and then they sat in the shed until December 2015.
Since buying the GTR bar id planned on matching the paint as it wad close but by no means a match.
while i as at it i kept an eye out for a bonnet and grille.
I found a bonnet from AUSJAP. had several dents and dings in it but the price reflected it ($250). I tried to find someone with a ute or simialr to help me pick it up but to no avail.
Here is how i got it home. Safe to say i got a few looks ont he drive home. :rofl2:
Started to strip back the paint around the dents so that i could hammer/bog where needed to get it back into shape.
uncovered holds that show it previously had an N1 lip.
IMG_0837_zpsfnaxlhqr.jpg.
My plan for the front end was to do as much prep as possible and supply anything needed before giving it to a professionally painted.
i spent a few days getting it as close as possible but some of the crease dents proved extremely difficult for me (first time doing any real panel beating)
So i sent it off to Pearl Factory to finish the prep work.
Shortly after this was the result.
Meanwhile i was busy working on the front bumper. i managed to source another bumper so that my car did not have to be off the road for any length of time. as a bonus this bar did not have any cracks in it to deal with
The hardest part was inside the vents
I Pulled the guards out of the shed and test fitted them up to the car. looked mint good fitment and no ugly vents
thought to myself why not roll them when they do't have any paint on them
bad idea. note to self Alloy is very soft.
to get the wheels to fit up right i borrowed some spacers from mates. finally effective wheel size to get them to fit.... this si with a 245/40 as well
at this point i sold the guards i had had for over a year and set on the hunt for another pair of un modified ones...
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
