If you go AWD, then no sideways fun. But a 26 swapped GTS4 sounds good... Have both?
way i see it
AWD good for Grip and potentially safer/faster around track and during "spirited" driving. But worse for Skids and U-turns
yeah you can get the variable ones which you can go from 100/0 right up to 50/50 drive bias. but the AWD chassis still has less lock and more weight
  • 3 weeks later...
Unfortunately i was unable to look any further into the GTS4. but here is a potatocam drive by to enjoy
I plan to film a better clip at a laterdate.
  • Like 3
  • 3 weeks later...
In an effort to reduce the laggy feel i went and bought a 4.36 ratio diff to replace my 4.08. the whole time i thought i had a Nismo GT 2 way but as it turn out it was a 1.5way hard to tell until i looked at it side by side with the new 4.36 nismo 2 way i bought. the new diff i bought is a 5 bolts vs the 6 bolt i had before. so nice upgrade there
i also wanted to fix the excessive front camber i have which was -3.8'. I did this by buying some superpro adjustable poly bushes. the old ones literally smelt like poo when we pushed them out haha
got under the car to swap out the diff and noticed this
subframe had to come out to fix this and at the same time i noticed my exhaust had done this to the rear bar
also the bushes were well buggered. I had been using metal subframe lock collars but it really was a bandaid solution.
burning out the old bushes.
ended up with whiteline poly bushes. i toyed with the idea of metal subframe risers but the whitelines came up for a good deal and it is still a street car. however even with a press the back two bushes were a pain to do and ended up up having to make this contraption up to get them in. Made from two Daihatsu strut tops drilled out and a pulley puller with a breaker bar and a jack pole
while it was out i scrubbed up and painted the subframe and arms. looked nicer imo and protects from rust
  • Like 1
  • 5 weeks later...
Booked a track day and was able to finally to stretch the cars legs with the new tune.
Bought a new set of wheels for track use, 17x9 +25 Rays Volk TE Fortresst. think old TE37 + AVS model 6 for the style and fitted up some brand new Hankook RS3 tyres to them in a 255/40/17. Got some help fitting them up :thumbsup:
The wheel and tyre combo was bigger in practice than in theory. In theory they should have been +5mm each side fro tyre and -3 offset on the rim resulting in +2mm on the outside edge and 8mm on inside effective when compared to my 17x9 +22 AVS T7 with 245/40/17 but the Hankook tyres were bigger resulting in some rub. haha
sorted that out then on to wiring. perfect thing to be doing at midnight the night before track day.
Got out to Mallala nice and early and unpacked the car
13047788_908048009292543_892282480551732
out on track
13055711_908046672626010_833905046696944
13029710_1046899718716955_51798638418556
ended the day with a jerrycan rescue for one of my mates also driving at the day.
Short video of one of my laps. My phone ran out of storage before the best lap of the day but i managed improved a few seconds on my best lap last visit with a 1:26.8. Overall it was a great day with only a few minor issues but i drove there, did the track day. then drove home so i call that a win.
Edited by CRSKmD
hey mate
what did the new diff set you back? ditto with the rims?
got lucky $750 for the diff freshly inspected and setup and $850 for the set of rims with stuffed tyres
  • 2 months later...
not much new but i did have my car used for a photoshoot recently. So have some pictures. a few from my iphone and some from the photographer (watermarked ones).
heaps more on their site if people are interested
13254791_1069114493162144_56894265375088
13323612_1080829525323974_46009261908240
  • Like 3
  • 2 months later...
Small update:
R34 LCA with adjustable lock stops to get my turning circle back as R34 LCA stock lock stops  got in the way long before the rack maxxed out.
end result was ~1m my turning circle.
TRUST Turbo heatshield to try and keep some heat off vac lines that melted last track day ...and for some bling haha
13662526_10155176736019896_372109798_o_z
13647235_10155176735154896_849870771_o_z
also picked up a hand held gimbal to muck around with and shot a bit of driveway test footage below
  • Like 2
  • 3 weeks later...
Signed up for another grip day at Mallala.
arrived bright and early and got the car unpacked and setup
Convinced my mate to come out in his RWD manual stagea.
mid turn in, Easy to see the tyres cross section here haha
pitwall ft. "genuine" (fake) GTR grill doing its thing... i call it dynamic aero
nice deserve range of cars in my session
All in all a great day. Smashed my old PB and had a great time
On 10/1/2016 at 7:49 PM, Tom101 said:
Looks really clean! shame about the crash
Cheers mate, it was a kind of a blessing in disguise as without it i likely wouldn't have have the "bugger it just track it" attitude.
Prior to the crash it may have ended up getting a full body refresh and being super clean but the trade off would have been more cautious use and less/no track time
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
