Finally addressing my catch can and oil setup
Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors)
First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit.
I could probably have laser cut and bent up my own ones but this took any guess work out
  • Like 2
  • 4 weeks later...
Looking at finally painting and installing my R32 GTR wing I bought back in 2018.
I got two quotes:
Quote 1: $880 includes: wing, spare boot, holes welded up prep/paint.
Pro: full boot with wing AND hole-less boot with lip i can swap between
Con: $$
Quote 2: $330 wing only.
Pro: cheaper
Con: lose my (relatively) rare no holes sedan boot
Also to consider I do plan on painting my whole car at some point "soon" (been saying that since 2018)
Anyway Enjoy these All Japan Day 2025 pictures of my 4 door, still rocking the Calsonic Livery!
Rolling in
Interior shot
Matching Peer Pressure Racing overalls are pretty cute ngl.
This year was a hard 1990 cut so I got to be over with all the older cool stuff
Next to arguably the best car there. A mighty S-Cargo
  • Like 2
Love the purple accents in the car! It all comes together really well with the cage, boss kit and other little bits. Nice work all around!
What colour are you thinking for paint?
Thank you! The matching touches really ties it all in.
If/when I redo the whole car it would likely be the same colour I did the Engine Bay/Brakes/Cam covers in 2018. or something adjacent
On 1/26/2018 at 3:06 PM, CRSKmD said:
for my first time painting with pearl in a 3 layer job im pretty proud of what i managed to accomplish! the photos simply do not do the paint justice
  • Like 1
Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards.
Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought.
So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate.
I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate.
I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf.
Fuel tank foam as extra cam cover baffling?
I can't help with the cam stud clearances (are studs really even needed??) but I have been running fuel cell foam over the factory baffles in the race car for years and they have been doing a reasonable job of keeping blowby under control....almost never have to drain the catch can even though the clearances are pretty loose
The studs are needed to run the splash plates/ full length baffle plates
do you have a link to which foam you used? I have seen autosport had the yellow stuff that’s E85 safe.  https://www.autosport.com.au/fuel-tank-foam
I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused :)
I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle.
So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table).
plans short term are:
  • full length splash plates
  • remove oem cam cover baffle add foam and reinstall
  • at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump)
Yes the ~340,000km unopened motor is probably not helping things
On 4/23/2018 at 12:52 PM, CRSKmD said:
also sneaky catch can drain
Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
  • Like 1
What size bolts did you use to reattach the cam cover baffles? Thinking it will need to be M3-M4
Yeah pretty sure they are m4, but best to check, and perhaps use new hardware
Also don't over torque them......there was that one time I lost an expensive engine after a workshop overtorqued one of those bolts and it ended up in the oil pump (no, I don't know why they removed the intake mesh either)
  • Confused 1
So, barely torque them, but add a drop of Loctite just to be sure?...
RB20/25 covers don’t have threaded fasteners stock like RB26 covers. They are blind rivets so I will need to drill out and tap threads. I bought some M4x6mm button heads and will report back once done if I chose correctly length wise.
have also got some loctite
  • Like 1
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
