Finally addressing my catch can and oil setup
Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors)
First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit.
I could probably have laser cut and bent up my own ones but this took any guess work out
  • Like 2
  • 4 weeks later...
Looking at finally painting and installing my R32 GTR wing I bought back in 2018.
I got two quotes:
Quote 1: $880 includes: wing, spare boot, holes welded up prep/paint.
Pro: full boot with wing AND hole-less boot with lip i can swap between
Con: $$
Quote 2: $330 wing only.
Pro: cheaper
Con: lose my (relatively) rare no holes sedan boot
Also to consider I do plan on painting my whole car at some point "soon" (been saying that since 2018)
Anyway Enjoy these All Japan Day 2025 pictures of my 4 door, still rocking the Calsonic Livery!
Rolling in
Interior shot
Matching Peer Pressure Racing overalls are pretty cute ngl.
This year was a hard 1990 cut so I got to be over with all the older cool stuff
Next to arguably the best car there. A mighty S-Cargo
  • Like 2
Love the purple accents in the car! It all comes together really well with the cage, boss kit and other little bits. Nice work all around!
What colour are you thinking for paint?
Thank you! The matching touches really ties it all in.
If/when I redo the whole car it would likely be the same colour I did the Engine Bay/Brakes/Cam covers in 2018. or something adjacent
On 1/26/2018 at 3:06 PM, CRSKmD said:
for my first time painting with pearl in a 3 layer job im pretty proud of what i managed to accomplish! the photos simply do not do the paint justice
  • Like 1
Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards.
Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought.
So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate.
I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate.
I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf.
Fuel tank foam as extra cam cover baffling?
I can't help with the cam stud clearances (are studs really even needed??) but I have been running fuel cell foam over the factory baffles in the race car for years and they have been doing a reasonable job of keeping blowby under control....almost never have to drain the catch can even though the clearances are pretty loose
The studs are needed to run the splash plates/ full length baffle plates
do you have a link to which foam you used? I have seen autosport had the yellow stuff that’s E85 safe.  https://www.autosport.com.au/fuel-tank-foam
I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused :)
I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle.
So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table).
plans short term are:
  • full length splash plates
  • remove oem cam cover baffle add foam and reinstall
  • at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump)
Yes the ~340,000km unopened motor is probably not helping things
On 4/23/2018 at 12:52 PM, CRSKmD said:
also sneaky catch can drain
Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
  • Like 1
What size bolts did you use to reattach the cam cover baffles? Thinking it will need to be M3-M4
Yeah pretty sure they are m4, but best to check, and perhaps use new hardware
Also don't over torque them......there was that one time I lost an expensive engine after a workshop overtorqued one of those bolts and it ended up in the oil pump (no, I don't know why they removed the intake mesh either)
  • Confused 1
So, barely torque them, but add a drop of Loctite just to be sure?...
RB20/25 covers don’t have threaded fasteners stock like RB26 covers. They are blind rivets so I will need to drill out and tap threads. I bought some M4x6mm button heads and will report back once done if I chose correctly length wise.
have also got some loctite
  • Like 1
Got started on the modification to make these splash plates fit over the long weekend.
First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28
Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle.
As seen in other thread here is what is inside the stock baffles
I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm.
Next was to tap the threads using a cheap bunnings kit M4x0.7.
With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell.
I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held.
Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too.
Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers..
Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates.
oh and some lock nuts for the splash plates of course.
Edited by CRSKmD
typo
I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
  • Haha 2
2 hours ago, Duncan said:
That cannot have been a fun set of drilling.
The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
