No, none of our classes allow E85, and yes I check it regularly (every engine change) and there has been no deterioration, just a bit of discolouration
Huh, you are driving a Subaru now? :D
Or maybe it is you who is driving up RB prices...
  • Haha 1
I hope you mean engine oil change haha
I didn't mis-type
  • Sad 2
16 minutes ago, MBS206 said:
Duncan often changes engines before changing the oil...
Indeed, it is much easier to get at the filter with the engine on a stand
  • Haha 2
You don't need to lean as far to pour the oil in, or change the spark plugs either 😛
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
