Hey guys I just bought a R33 GTS-T and it's a great car but the tyres on it are on there way out. I've been driving it around a bit and in the dry they seem ok but in the wet and not even on a hill there is no way I can take off without losing traction. Basically what I'm looking for is a set of tyres that have good grip in the wet and don't make too much noise.
What do you guys recommend? I am thinking of going with the Bridgestone Potenza Adrenalin RE002.
By the way I did look at the sticky post but there is too many pages and different ratings on tyres. My price range is flexible, obviously cheaper the better but if I have to fork out for a good set I do not mind - probably keep it under $1000 for a set though.
Cheers.
https://www.sau.com.au/forums/topic/452541-r33-gts-t-best-tyres-for-in-the-wet/
KU31. Cheap, cheerful and they work.
KU36. Cheap, cheerful, stick like shit to a blanket, noisy as buggery, but worth it.
There are many other options, even some very cheap ones, such as the Federals, Achilles, etc.
Most serious brand (Goodyear, Dunlop, Bridgestone, Pirelli, Yokohama, Toyo, etc) tyres that are not really OLD (like the FK452) are going to cost more than $1k per set.
Perhaps I should confess that the 36s are not the BEST in the wet. They work fine in the wet, but they won't handle standing water. Not enough tread on them to pump a LOT of water. But I've never had low confidence with them in winter. Just don't lean on them cold, and don't try to tow skiers.
I'm a big fan of Maxxis tyres and they are more than reasonably priced. I have a pair of terrible tyres on the back of my GTST at the moment that came with the wheels I bought, they do the same thing in the wet as you describe. After a good research session the other day I settled on getting a couple of Maxxis MA-511 to replace them. They seem to be a newer version of the Maxxis MA-V1 which I have had a set on the front for years and can't say enough good things about.
A good tyre review and opinion site to check out and see how a potential purchase is going to stack up is http://www.tyrereviews.co.uk/
Edited by Malakai
Nitto INVO tyres aren't too bad in the wet either and provide decent dry weather grip.. Great daily tyres IMO and not too noisy.
At the same time, perhaps look at lightly shimming up the diff OR just going with a new mechanical diff. I find the stock VLSD likes to single peg on days, it's very temperamental like a female.
I'm running Goodyear Eagle Asymmetric 2 in 17" and they are really quite good in both dry and wet. Paid about $900 new for a set online. Always check the date of manufacture before buying though.
I just took a set of those off my car. Totally underwhelming tyre. Not awful. Just.....not great. Only lasted 12000km.
Interesting, what did you have prior and what are you running now, out of curiosity?
KU36 before. And oddly enough, KU36 again. I was actually intending to get RS-3s, but they're unavailable for the next 3 months.
The Goodyears had this horrible tendency to judder as I turned out of my driveway (like......really really low speed understeer!). I spent ages trying to work out if it was a tyre issue or an alignment issue, including spending on 2 extra alignments that the car wouldn't have gotten. So, on the Tuesday morning with Goodyears on it judders on the way out. On the Wednesday morning with the KUs on, no judder. I think that answered that question. That sort of crap pretty much explains my experience with the Goodyears.
I've used KU36 probably 7/8 years ago - wasn't a total fan of them to be honest..
But then again, they were never taken on the track. I found they did like to understeer until it had some decent heat through them
Maybe. Dunno about that pricing here in Adelaide though (as in, getting Nitto for pricing that's competitive with the KU36 price). The Tyrepower store I use are good blokes who are aware that I have previously bought in tyres from the eastern states and from the US to get good stuff at good pricing, and so they tend to offer me the best pricing that they can. They handle Nitto also, and the pricing on them was not attractive last week.
I'm up for new tyres soon too, not sure I want to put NT01s at the rear.. that might result in a broken gearbox :(
I'm running NT01 at the front, surprisingly they're not too bad in the wet!
Ive got Hankook Ventus 452s on the mrs car and also on my XR6 work ute which has an alloy tray and even in the wet in 1st gear the traction control light doesn't come on! Pretty impressive all rounders actually. They are quiet with very good grip wet and dry are reasonably priced.
I also am not a fan of the KU36. The RS-3s shit all over them in all conditions and are also probably a bees dick quieter. But they aren't what you'd call quiet lol
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
