Hey guys,
I've entered for the Sunday now as well and looking forward to getting back out at PI and competing in the championship this year.
For those who don't know me yet I've got a VX SS Commodore with an N/A LS1 putting out around 310rwkw and I ran a 1:54.9 last time at PI. :)
  • Like 1
Haven't entered yet but I will at some point.
Anyone else going for the first time?
At the briefing they usually ask if there are any first timers. Just let them know and they'll either do a parade lap at low speed or get an experienced driver to passenger with you on the first session.
Yep PIARC days they group you on times and shuffle groups during the day on times
Didn't think they did at the last one, might depend on how many entries and the time spread?
They might factor in the car class for groupings along with specified time. Both are on the My Car page on www.meecamsau.com. Most people would be E-H?
Motorsport Information
Group 5 Sprint Class
STANDARD CAR CLASS
Class A - Up to 1600 cc
Class B - 1601 to 2000 cc
Class C - 2001 to 3000 cc
Class D - over 3000 cc
MODIFIED CAR CLASS
Class E - Up to 1600 cc
Class F - 1601 to 2000 cc
Class G - 2001 to 3000 cc
Class H - over 3000 cc
RACING CAR CLASS/SPECIALS
Class I - Closed Racing Cars up to 2500cc
Class J - Closed Racing Cars 2501cc over
Class K - Open Racing Cars. All Capacities
actually most of entrants would be in A-D
E-H are those with engine swaps, stripped down with aero work...think richo's skyline.
http://www.piarc.com.au/files/Feb%202015%20Sprint%20Regs.pdf
Classes A, B, C & D are for road-registered cars using generally road-going equipment only. All cars using racing
tyres, or slicks, will be classified as specials, as will be excessively modified road cars. The organisers reserve the
right to re-classify cars, following vehicle scrutiny. For full details of modifications allowed in each class see Group 5
Speed Event regulations. The organisers reserve the right to amalgamate classes if in their opinion entries are
insufficient to warrant a separate class.
I'm in Class H with my car when I compete at PIARC events...
Anyone that is entered and/or spectating - Please post up to confirm you are coming.
Also if you are doing a single day OR the two days (there is Prac on Sat some are attending).
I need to know for catering purposes for lunch of Steaks/Skewers and the like over the two days.
Thanks in advance!
Thanks in advance!
In for proteins
Just racing on Sunday
Thanks in advance!
Robyn and I will be there on Sunday for sure, steak will be needed :P
STANDARD CAR CLASS
MODIFIED CAR CLASS
I just put down Modern 2WD for the meeca site lol.
f**ked if I know TBH... I just put down the laptimes section though, I think that would hold far more relevance.
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
