Hey guys,
I've entered for the Sunday now as well and looking forward to getting back out at PI and competing in the championship this year.
For those who don't know me yet I've got a VX SS Commodore with an N/A LS1 putting out around 310rwkw and I ran a 1:54.9 last time at PI. :)
  • Like 1
Haven't entered yet but I will at some point.
Anyone else going for the first time?
At the briefing they usually ask if there are any first timers. Just let them know and they'll either do a parade lap at low speed or get an experienced driver to passenger with you on the first session.
Yep PIARC days they group you on times and shuffle groups during the day on times
Didn't think they did at the last one, might depend on how many entries and the time spread?
They might factor in the car class for groupings along with specified time. Both are on the My Car page on www.meecamsau.com. Most people would be E-H?
Motorsport Information
Group 5 Sprint Class
STANDARD CAR CLASS
Class A - Up to 1600 cc
Class B - 1601 to 2000 cc
Class C - 2001 to 3000 cc
Class D - over 3000 cc
MODIFIED CAR CLASS
Class E - Up to 1600 cc
Class F - 1601 to 2000 cc
Class G - 2001 to 3000 cc
Class H - over 3000 cc
RACING CAR CLASS/SPECIALS
Class I - Closed Racing Cars up to 2500cc
Class J - Closed Racing Cars 2501cc over
Class K - Open Racing Cars. All Capacities
actually most of entrants would be in A-D
E-H are those with engine swaps, stripped down with aero work...think richo's skyline.
http://www.piarc.com.au/files/Feb%202015%20Sprint%20Regs.pdf
Classes A, B, C & D are for road-registered cars using generally road-going equipment only. All cars using racing
tyres, or slicks, will be classified as specials, as will be excessively modified road cars. The organisers reserve the
right to re-classify cars, following vehicle scrutiny. For full details of modifications allowed in each class see Group 5
Speed Event regulations. The organisers reserve the right to amalgamate classes if in their opinion entries are
insufficient to warrant a separate class.
I'm in Class H with my car when I compete at PIARC events...
Anyone that is entered and/or spectating - Please post up to confirm you are coming.
Also if you are doing a single day OR the two days (there is Prac on Sat some are attending).
I need to know for catering purposes for lunch of Steaks/Skewers and the like over the two days.
Thanks in advance!
Thanks in advance!
In for proteins
Just racing on Sunday
Thanks in advance!
Robyn and I will be there on Sunday for sure, steak will be needed :P
STANDARD CAR CLASS
MODIFIED CAR CLASS
I just put down Modern 2WD for the meeca site lol.
f**ked if I know TBH... I just put down the laptimes section though, I think that would hold far more relevance.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
