Motorsport Round 1 - Phillip Island
ssxRicho
Catering update thus far below.
If you have not advised, do not forget to do so!
Saturday
r31nismoid
matlowth
ripper_bravo
Snowman
acsplit
Odium
FINER6
Sunday
r31nismoid
matlowth
ripper_bravo
Snowman
acsplit
Odium
FINER6
llama_au
vetter2769
Tony Olsson & Robyn
blah_blah
Brett SS
Borci88
miniwog
Richo
If this is a sign of what SAU-Vic motorsport is going to be like this year - it's going to be a eff-ing big C/Ship!!!
NICE!
  • Like 1
I managed two track days at PI last year, agree it's amazing. I'm just in money saving mode. And I run like a 2:14...
Yeah not great :P I'd just get in everyone's way.
Myself and im sure a few other dont plan to set the world on fire
Come on the track Juliette :)
Free tax advice if you do on the day :P
first bit of financial advice..stop spending money on cars and track days ;)
It's getting so I may need to employ Tony's services and make these entries disappear from my family financial accounts. :whistling: Even with Jen's biggest shopping adventures, they aren't comparable.
I will also be one of those slow people. Planning to come on Saturday and get some track time and up my skills, but need to upgrade my Cams and figure out why i cannot seem to log into the sign in page at the start of this thread.
Godamnit. I want to but shouldn't but want to but erghhhh. I'll think about it.
Okay fine, entered for Sunday. You all had very convincing arguments. Looking at the entry list, I will most definitely be holding up traffic. My car has also just got slower, took out the tune, lost 12rwkw which makes it go from slow to slooooooooooooow. Sorry, and my bad in advance.
Put me down for food Saturday and Sunday Ash, I think I'll head down on Friday and make a long weekend out of it :)
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
