Motorsport Round 1 - Phillip Island
ssxRicho
Okay fine, entered for Sunday. You all had very convincing arguments. Looking at the entry list, I will most definitely be holding up traffic. My car has also just got slower, took out the tune, lost 12rwkw which makes it go from slow to slooooooooooooow. Sorry, and my bad in advance.
Put me down for food Saturday and Sunday Ash, I think I'll head down on Friday and make a long weekend out of it :)
Haha good work Juliette :thumbsup:
Nah, it was occasionally throwing CELs and putting the car into limp mode so I cracked it and ripped it out. Might do it again with a different ECU and tuner at a later date when more mods would make it more worthwhile.
Hey guys, Im a new member this year and I was thinking about coming down for the Saturday to learn the track, I have a stock r33 gtr v-spec what are your thoughts on how the car would perform, is it critical that I do such things as upgrade the oil cooler?
I wouldnt say its esstential, but you won't be able to do as many laps before the oil temps get pretty hot
As long as you have an oil temp gauge to monitor your temps you'll be fine
As a guide on my stock GTT no oil cooler i got about 4 laps at Sandown before oil temps got above 120c
1. Ensure you have oil temp gauge.
2. Ensure you over fill the sump by 1 Litre before attempting track duties.
3. Ensure all other fluids are topped up and good to go
4. If brakes are under 30% pad, fix that up.
5. Ensure you READ the supp regs and sort things out like Fire Extinguisher, Battery point markers etc.
Otherwise you should be good to go. Long term it would be a good idea to sort an oil cooler and pay some attention to better brakes if you've not done half decent pads/rotors as at tracks like Winton you're gonna have a tough time.
There is sooooo much experience in the SAU-Vic track group, it's the best place to come if you want to do some laps in a Nissan. And if there isn't someone that can't answer your questions or help you out, then you've got something really wrong and should probably start worrying :P hahaha
Most all though remember to have fun as that's what it's all about. There are no heros at our events, just a bloody good bunch of guys so make sure you find the banners and come say a g'day.
  • Like 1
It's not an SAU track day without people scrambling to add upgrades and put their car back together in time :D I'll see you guys at a few rounds this year hopefully... won't be at PI though.
sure sure, you said that last year, year b4 and I think maybe the one prior to that...(or was that turbo gasket year)
Ha! you're one to talk Martin...
car saw the track briefly last year, a few early the year b4.
Entered our Motokana this year and waiting for the SAU sandown entries to open...
so to quote this dude who used to turn up to track days
cool story bro.
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
