Squires Loft Nunawading BBQ will be in attendance again this year for Motorsport Rounds where possible :D
Doh, can't make it, so looks like I'm going to miss out on a good feed as well as a run at PI
Does it cost anything to just to come down and spectate? Is there good parking spots for spectators?
can I park up inside the venue someplace?
also nismoid don't forget to add artichoc to the sunday list with me, cheers :)
Gonna be a hot one over the weekend
Do we have a garage sorted yet?
Wheres the best meeting point before hand?
Was thinking the Macca's/Coles servo on the left straight after getting off at the Monash on to the South Gippie Freeway.
Scrutineering begins goes from 7:30 to 8:30? Takes 1 hr 15mins to get there from this point
So meet there at say 6:15 a.m? Or too early :wacko:
What about United Cranbourne since it's the last spot for E85 before PI? I think it might be a little out of the way for some people but I'll be there at 6:30am.
Happy with that, im on e85 too. Cya there :thumbsup:
  • Like 1
UPDATED Squires Loft Nunawading BBQ LIST
Please confirm if you are not on the list!!!
Remember the BBQ is FREE for SAU-Vic members only, get those memberships in - support the club that is supporting you!
Saturday
r31nismoid
matlowth
ripper_bravo
Snowman
acsplit
Odium
FINER6
miniwog
llama_au
Mick - MiColour
Total - 10
Sunday
r31nismoid
matlowth
ripper_bravo
Snowman
acsplit
Odium
FINER6
llama_au
vetter2769
arctic-choc
Tony Olsson & Robyn
blah_blah
Brett SS
Borci88
miniwog
Richo +2
atko92 +1
gtr jet +1
Mick - MiColour
Total - 24
Green_S13 - you still don't have a membership tag! Get that membership sorted.
jayjayjay - same as above
INXILE - same as above/above
Suggest you boys flick off an email to Anna: [email protected]
I did the last round of member updates this morning and none of you boys were on it!
Looking like a MASSIVE weekend for SAU-Vic Motorsport. Great start to the season
Flick off email to Anna :)
You would've have a forum tag if you were not paid-up. So that's ok... You sometimes need the sticker for CAMS though (when they check cards)...
That reminds me, NFI where mine is
  • Like 1
Hey guys Saturday will be my first race meet, just to confirm is there anything extra I need to get my car on the track other then
Blue triangle to locate battery
Tyre valve caps, ( plastic or metal ? )
Fire extinguisher with metal bracket
Car number ( can I write this on the window )
Car in roadworthy condition, full length clothing and Helmet.
Any advice is much appreciated.
Tyre valve caps, ( plastic or metal ? ) Metal are generally prefered
Car number ( can I write this on the window ) PI will supply you with a number when you sign in
What you've listed is just about all you need for the day.
Then it's just tools for maintenance throughout the day + something to check tyre pressure.
Also food and drinks if you don't want to purchase stuff from the canteen.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
