Motorsport Round 1 - Phillip Island
ssxRicho
GTR jet & INXILE I'll do some digging tonight & advise the outcome, if you haven't already please email [email protected] with your details
Green s15, I'll be finalizing your membership tonight so will be posted tomorrow morning to you
Anyone else with membership issues please email me - [email protected]
I had a system issue which prevented me receiving new membership applications & hadn't received any forms since 5th January, but with this now sorted I've had them sent on to me & put in a few extra hours over the last week to try get everyone's membership packs out by tomorrow at latest :)
Also - If you haven't received your membership pack or renewal in post by 5pm Thursday & you're entered please email me, I'll send you a letter of confirmation via email that you will be able to show on Saturday/Sunday if the card doesn't arrive in time.
Cheers,
Anna
  • Like 2
I want a bottle opener :dry:
It is a renewal gift, you should get one when you renew next.
Hi all,
100% up to date with the renewals and new memberships now so if you haven't received yours by Friday and you are racing please let me know on email [email protected] so I can send you a pdf letter in meantime.
Cheers,
Anna
  • Like 2
No ones emailed me so far so fingers crossed that means Aus post did their thing & you all received your renewals and memberships & I don't have to spend my Friday night generating membership confirmation letters [emoji41]
I forgot about that sorry. Mine never turned up so I might need one of those letters.
are you just going to watch Steph? Jake and I will be in Carlton around 7.30ish, but I'm not bring my skyline, just in the ute coz its on LPG.
yes im just watching :)
wanna meet us near Cranbourne at say 8ish?
we are leaving carlton area at about 7am....
Got knocked back for windscreen/suction cup mounted timer and camera yesterday (been running the same setup for about 5 years)
Any one else had/having the same trouble today?
Still annoyed at the ponytail CAMS scrutineer. Knocked me back for my Motocross helmet because apparently the chin part extends out too far. Told me to go speak to Clerk Of Course and see if he can over-rule it. Eventually he over-ruled it and then the scrutineer tells me, "They're not banned yet, but they're trying to ban them right now, it's yet to be updated".
WELL IF IT'S NOT f**kING BANNED THEN IT'S NOT f**kING BANNED!!!!!
In other news though I had a great day, good to finally get out there this year, definitely need to get myself some coilovers though!!
  • Like 3
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
