^ ummmm...now is probably not the time to tell you that he didn't even scruntineer my car, look at my helmet, extinguisher or car in general. I literally drove past him (at about 7:15am mind you) got a sticker and continued on my way.
Change of subject, awesome day - Ash, thanks for the delicious BBQ, SAUVIC, thanks for the garage for chill times.
  • Like 2
Yup they went through the cars a mate of mine was done for suction cup, I got told I had to remove my steering lock as my car isn't registered
Got told the same thing about my steering lock too
I got the steering lock thing too... and that i need to have a key hanging out the boot lid....
just let it slide, if they actually stopped anyone racing then it night have been a different story.
I just happened to be on PI for a holiday, early Saturday morning walks I bumped into the Heasman's crew and easily got talked into heading to the circuit to check things out.
Managed to meet a couple of SAU members, checked out the R33 GTR, R34 GTR, S13, S14, S15, R33 GTSt, Commodore, and the Ginetta (from a distance).
Today was a travel day to return home, pity I missed a chance to meet more SAU members. The Vic scene looks healthy, and people approachable for a yarn. Club motorsport is where it's at.
And I finally got to see why PI is raved about - I'd like to bring my car there for a run but it's a long drive from Qld. The only negative I found was the weather down in those latitudes is everything it's cracked up to be... :yucky:;)
  • Like 2
Evo Brake rotors are warped and shuddery when hot, Pads almost done...
And ABS kicking in constantly after I got some heat into the race spec nankang tyres ;)
Either way, got a few sessions in because I decided to call it to preserve my daily, was good to see how it performed out there. Would be a monster on good tyres and some fresh rotors / pads :) Was a lot of fun wrestling with it during a 4 wheel slide :D
I didn't even get out of my car during scruitineering, rolled in... he opened the boot and closed it in 2 seconds, same with the bonnet, stuck a sticker on and off I went. Didn't even look at my fire extinguisher or helmet :P
Really good day and heaps of new people to talk to! Very positive to start to the SAUVic Motorsport Season
I walked into the office to sign in, and the girl saw my SAU Shirt and said "Damn, another one of you!!"... and the guy said to her in a loud whisper "Shhhhhh, they're funding the day!"
did lol
  • Like 2
First time at PI and had an awesome day!
Only managed one or two sessions but car should be right for next time
I need to get myself one of those SAU Motorsport shirts!
And thanks to Ash for the BBQ!
Did you end up having enough fuel to get home? I got home with 1/3 of a tank and 30L spare in jerries haha.
Yeah had enough fuel!
Only becuase i missed 2 sessions and only ran half laps of another 2 sessions .
Had about 1/3 of tank. Used 1/2 a tank and 3 jerry cans for the day still
Saw you beep on the way home :thumbsup:
  • Like 1
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
