Haha if it makes you feel any better John, I don't have any GoPro footage to rub it in! But I'm sure the other guys can make up for it ;)
Actually I do! Damn GoPro battery died as I rounded the final corner on my next best lap (1:52.1504 vs 1:52.1412 so close enough!). A 51 seems so close...
That last corner entry, pegged to the floor!
Hehe yeah full throttle from the exit of turn 10 basically. I think the extra camber helped in that regard (~3 front, 2.5 rear)
Finally had a chance to sit down and see what i got from the weekend.
PB on Sunday! happy with that.
Saturday was ment to be a bit of fun in the Stagea that ended up not as fun.
Got a couple of laps in before radiator couldn't handle the heat.
After having to take cameras and loggers of the windscreen only ended up with one vid, lucky it catches the radiator pop.
Edited by INXILE
Have any of you guys driven to and from Winton on E85? With current economy I'm budgeting bringing a full tank of E85 and just over 100L spare to race around on and get me home... shit ain't economical!
Get a trailer then...
Not worth it to drive that distance burning up E85, and if you have semi slicks it's even worse.
Yeah I wouldn't risk it. You'd need 5+ Jerry's just to make sure you'd be able to race all day and get home. I don't know how'd you'd fit them in a car with whatever else you need to bring.
Safer just to trailer it.
You're not trying hard enough! Plenty of room in a prius, should be a easy as in a skyline!
That said, the shitty economy does make it a pain in the arse for the long haul. According to the website there isn't a united beyond Somerton with E85.
  • Like 1
The middle section section is a typical wheel well but only the 2 with labels are standard height cans.
The 2 yellow and outer red ones are all low profile cans like this which make life a lot easier. Can still fit these in the boot with the floor liner in place and not using the wheel well:
https://www.masters.com.au/product/900031253/scepter-petrol-jerry-can-squat-20l.jsp
  • Like 1
I can fit 80 litres in the boot of the 33, and a further 50 litres in the foot wells behind the front seats. I can definitely carry enough, it's just trying to work out how much I'll need SAFELY, I'm thinking I'll need about 120 Litres to make it safely.
Mehhhhh, I think I'll just not put the passenger seat back in my car... plenty of room for activities :) Because nothing screams safely like heading towards Winton at 110km/h with 120L of fuel in the cabin
  • Like 1
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
