Hey guys names Joey I live in Caboolture and this is the build for my r32 gtst, I was originally building the motor to put in my rodeo ute but later decided that a motor with all the parts I had chose to use deserved to be in a better car so I was on the hunt for an R32. After searching for a couple of months I found this (which my little brother loved).post-132812-14209711519319_thumb.jpgpost-132812-14209711631474_thumb.jpg
After a couple months of collecting parts I went to pick up my Tein super streets from Mercury Motorsports and saw this post-132812-14209711858823_thumb.jpgpost-132812-14209711957662_thumb.jpg
And after about 30 minutes of talking about it with my little brother he decided he was going to buy the black one off me and I would buy the yellow one so It got put at a tow truckpost-132812-1420971261881_thumb.jpg
https://www.sau.com.au/forums/topic/452578-big-bird-the-r32-gtst/
Ok so after a couple of days owning It I pulled the old coilovers out and put the Teins in
Next I started pulling the existing engine and gearbox out which only took about 3 hours to Pull it all outpost-132812-142106466379_thumb.jpg
Now the engine was ready to be sent off to be machined so that everything was and good and better got a couple of pictures while the machining was being done, the block was bored, honed and acid bathed an the crank was balanced and a crank collar was fitted. The original crank that came with the block turned out to be bent but I luckily found one quickly and it pretty cheap.
The machinist cleaned up the ports, put in new valve springs new retainers skimmed the head a little and cleaned out the lifters.
  • Like 1
Ok so found the photos of the intake manifold, exhaust manifold and turbo :)
As you can see I have went with the plazmaman plenum, throttlebody and the black plazmaman fuel rail. Exhaust manifold is a t3 single entry 6boost and the turbo is a GTX3582r with a .82 rear housing
  • 1 month later...
  • 3 weeks later...
So done a bit of work on the car over the weekend, we mocked up the surge tank and my external fuel pump only took a photo of the car on the hoist though, but will post some pics of where the pump and tank are sitting as we aren't putting it in the boot.
I went with the aftermarket industries under car surge tank.
Also got the injectors and fuel rail on and walbro intank put in aswell.
I have decided to use the siemens 2433cc injectors so I don't have to upgrade.
Edited by joey91
  • Like 1
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
