Hey guys, I'm thinking of selling my V35 350GT sedan with rare 6sp manual transmission. I basically want to see if there is any interest. It's a 2003 SP model with 94xxx kms. Can supply more info if needed. Shoot me an offer if your keen.
post-138259-0-00384000-1421018153_thumb.jpgpost-138259-0-18904200-1421018148_thumb.jpgpost-138259-0-10828700-1421018157_thumb.jpgpost-138259-0-01228700-1421018474_thumb.jpgpost-138259-0-03589500-1421018165_thumb.jpgpost-138259-0-95647400-1421018160_thumb.jpgpost-138259-0-93437300-1421018372_thumb.jpg
https://www.sau.com.au/forums/topic/452593-fs-qld-v35-350gt-rare-manual-sedan/
Yeah that's right. I know the sedan is a bit of a niche market so like i said im just seeing if there is any interest. I want to upgrade to a series 2 or 3 manual sedan or coupe (sedan preferred) and I want to know if it's worth paying the difference or just spending that money on go fast bits.
I would be looking for $16k
It's not a sat nav model so no need for English conversions.
It's a private import, one aussie and one japanese owner. Auction grade was 4.5B. I have all the import/export documents for it.
Thanks.
sorry for the repeat post, im new to the site...
but here are some more details for anyone who is interested:
Automatic HID xenon headlights
Sports tuned suspension with Tokico red shocks and stiffer springs
Viscous Limited Slip Diff
VDC ( traction control ) switchable
Stability control
6 stack in dash CD player
BOSE stereo with 6 speaker + subwoofer and steering wheel controls
Automatic dual zone climate control
17" alloys
Private import in Feb 2013 with an auction grade of 4.5 B and 71000km. Currently at 94xxx kms. (Daily driver so will go up slightly)
Import/export papers and auction sheet will be provided to show this and that the odometer reading is genuine.
Clear title
Non smoker car
P Plate legal (QLD)
RWC will be provided on sale
3 months rego
Inspections welcome
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
