Fs: (qld) V35 350gt, Rare Manual Sedan
Yeah that's right. I know the sedan is a bit of a niche market so like i said im just seeing if there is any interest. I want to upgrade to a series 2 or 3 manual sedan or coupe (sedan preferred) and I want to know if it's worth paying the difference or just spending that money on go fast bits.
I would be looking for $16k
It's not a sat nav model so no need for English conversions.
It's a private import, one aussie and one japanese owner. Auction grade was 4.5B. I have all the import/export documents for it.
Thanks.
sorry for the repeat post, im new to the site...
but here are some more details for anyone who is interested:
Automatic HID xenon headlights
Sports tuned suspension with Tokico red shocks and stiffer springs
Viscous Limited Slip Diff
VDC ( traction control ) switchable
Stability control
6 stack in dash CD player
BOSE stereo with 6 speaker + subwoofer and steering wheel controls
Automatic dual zone climate control
17" alloys
Private import in Feb 2013 with an auction grade of 4.5 B and 71000km. Currently at 94xxx kms. (Daily driver so will go up slightly)
Import/export papers and auction sheet will be provided to show this and that the odometer reading is genuine.
Clear title
Non smoker car
P Plate legal (QLD)
RWC will be provided on sale
3 months rego
Inspections welcome
 Share
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
