Ive heard blokes doing 12-15000 k's plus track days no worries on the RS3's.
If its a weekend drive are you really gunna care about replacing tyres every 3 or 4 years? All you will care about is having the most grip ya can to make the most outta your toy when ya driving her :D
Well i know i do anyways lol
  • Like 1
Reporting back with pricing:
Michelin PSS $1550
Hankook RS3 $1150
Nitto NT05 $840
PSS is out of the question due to price plus the RS3 seems to be the pick of the bunch, based on feedback.
NT05 is most appealing due to price and availability so the question I have is the RS3 that much better or are we splitting hairs? The extra $300 doesn't bother me...what would u guys go for, keeping in mind I'd be lucky to drive the car once a fortnight (sad huh)
  • Like 1
I'd still say go with the hankooks mate ive personally never driven on the NT05's to know how much difference there would be between them. But i believe the hankooks would probably last alot longer as nitto use toyo rubber which is always a pretty soft compound. :)
Hey Mick do the 275/35s rub a lot, or only full lock?
I'll guess this is for me, yes at full lock they rub a bit, but there is two reasons for it 1) I should have got 30 series, which is the correct size for the 34, instead of 35 2) my rims are +12 offset and with +18 they wouldn't push forward or rear as much reducing the rub or even stoppng it altogether
U have a 34 right?
It gets me thinking whether I can go from the recommended 265/35/18 to a 275/30/18 as the lower series would help with full clearance but then again the profile is relative to the width so maybe the 30 series would have a higher sidewall than the 35 series...mine is an r32. Anyone know if this would work as I have 18x9.5+22?
PSS like other higher performance road tyres (continental etc) will mince the outside sidewall pretty easily on heavier cars. I'm going through this at the moment with my big tanker.
R32 GT-R but better, but you are carrying more speed... Really depends if you are doing track days or not as one track day
You've then got the more extreme performance of NT05/AD08/R-S3 etc. Can venture to the track an not be as worried.
If it's just street then it probably doesn't matter a hell of a lot and the NT05 for that price would seem the pick of the bunch.
If you were doing the track days the AD08® still seems to be most popular as the tyre is like a brick, sidewall of amazing excellence which gives the confidence one needs (and also decent wear). I loved my AD08 for that reason and went through 2 sets of them in my time on the 33R, they took such an epic beating - was very surprised. Just the price that is the killer.
R-S3 seem the better tyre for a single lap time, AD08 for the lap after lap.
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
    • We have an alignment shop out here that does what you're talking about but he wants like 800 AUD a pop. DIY is "cheaper" but once you start accounting for the value of your time I'm not sure it's worth it.
    • The main catch phrase for any car is "the eye of the beholder", and "personal tastes and preferences" And as for the plastic "flares", I honestly think they look cheap and tacky, and I cannot see them aging well, maybe if they were body colour they might look better to my eyes, but, I would still prefer it the were more like the older WRX STI models that had the wider body metal panels In saying all this 5hit, I wouldn't buy a new WRX again, even if it had the wide body metal panels
