Hey guys
Im about to buy this ecu and i need to know about the boost control with this unit. I know i cant just type in what boost i want to run on the ecu with the standard R33 gtst soleniod.
So if i get my hands on a avcr soleniod and use that in conjuction with the wolf3d software, that will give me complete boost control the same as any other EBC?
I dont want to spend a few hundred on a EBC if i dont have to if this method works. So just want to confirm if anyone has done this and it works ok?
Also i want to know if anyone has any base maps they could send me? I wanna have a go at installing it myself and if i could have a base tune to get me started that would be much appreciated.
My mods are
3" turbo back exhaust
Pod
FMIC
bosch 040
stock boost
Cheers
Matt
https://www.sau.com.au/forums/topic/45266-info-needed-on-wolf3d/
Guest darrinspencer
MJ I am in the small boat as you
I have the wolf computer but still have not fitted it yet
I pm Steve at SST a while ago the same question
his answer
"You can use the factory solinoid, but solder up the restrictor and redrill it to 0.5mm"
To us the factory solinoid I am pretty sure you need to unplug it from the factory harness and run new wires from the wolf computer?
Plug in the wolf and the boost solinoid will work with no extra wiring needed but if you want high boost you need to solder the factory restrictor and re drill smaller or fit a larger solinoid. Wolf car run any solinoid and works with inturnal and exturnal gates if you set it up right.AVCR solinoid is fine but save your coin and use the factory one with small restrictor.
  MJ said:
Yeah rsx84 for a rb25det
Steve or anyone else, if you could ever so kindly send a base map to suit the mods listed in my first post to mwat4901@bigpond.net.au that would be much appreciated :cheers:
Craz0 if u dont mind id like a copy of your base map just for referance
Cheers
Matt
Sent.Steve
yes i agree, the power FC is fairly restrictive with an automatic, especially because there is not many functions available for that type of tuning..
why dont you learn how to drive manual?... :jk:
the wolf has a wider range for the auto.. so good choice!
good luck with the tuning! :wassup:
Hi Abu, the standard engine ECU "talks" to the gearbox ECU and
(amongst other things) retards the ignition timing to smooth out the gearchanges. This also "unloads" the gearbox at the time of shifting, which lessens the torque shock on the auto. This extends its life considerably. The programming for this is quite complex as it has to account for gradients, as well as throttle position, gearchange point, engine rpm road speed etc. I suspect tha tthis is why Apexi don't make an auto PFC, they would have to charge a bomb to cover the cost of the programming t ocover the wide variety of power outputs. Noting that a standard ECU only has to account for standard power.
I have a Stagea almost here and it's an auto, good for towing the race car. So can you (or anyone else) tell me how well the Wolf handles the gearchanges in the auto?
I have recieved the maps, thanks for your help all :)
Sydneykid from what i have read from other people that have used this ecu in their auto skylines, they havent had a problem with the ecu except for the gearchange to be a little jerky. Maybe Steve can give a bit more of a insight on this?
I really like the software that comes with the unit, its really easy to understand and navigate. I cant wait to get this baby fired up now
Cheers
Matt
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
