sorry if this is in the wrong section, please move accordingly if so
Looking for a shop that can make me two pairs of caliper adapters (f and r, not dupes).
like all clueless morons on the internet I want them to be both good and cheap and yes I do want a god damn cherry on top too
am I dreaming asking for a shop to back up their product? or will they all say "for off road use only, no liability"?
Cheers
-A
Edited by Anti
https://www.sau.com.au/forums/topic/452667-brake-caliper-adapter-fab-sydney/
Even if they are up to the task, you'd be hard pressed to find anyone warranting them for street use. Big liability issues there. Unless they are capable of performing the engineering calculations / FEA modelling of the components, nobody is going to be willing to certify brake products for use on the street.
You would be better to speak with a consulting engineer, and get their guidance on material spec, thickness etc.
Or work with the fabricator to come up with a design, then see the consulting engineer to get his input.
If you can come up with a design that your engineer will approve; you will have no issues getting an engineers certificate to support the modification.
HOWEVER!
There is an old adage; and it is especially applicable with engineering work.
Yes.
Just to clarify, my previous post was referring to fab / machine shops. You can indeed get things certified for street use, but you need a suitably qualified / appointed Engineer or equivalent (depending on where you are). I looked into this several years ago (just needed to be MIEAust, which I was at the time) but my insurance costs would have been prohibitive. Would need to turn over tens of thousands a year to make it worthwhile. Not worth it to sign off on 1 or 2 jobs a year.
Edited by warps
The whole project is getting pretty spastic at this point so it'll be engineered again before it's back on the road. I'm not worried about having brake caliper adapters passed, cars come with them standard these days. It's lame that no one will support their product; may as well do it myself.
Yes, but you will find that OEM parts are often forged, heat treated, surface ground etc. to get the right fatigue life and ensure the mechanical properties are up to the task. They have a team of engineers designing every little component for the car on a multi million dollar budget, as well as a full warranty program (and legal support in case their products fail and cause deaths)
A lot of workshops cut their brackets out of a bit of 250 or 350 grade plate. Some use a plasma cutter, some use a water cutter, some machine them out of a billet. There's little to no engineering that goes into it (apart from dimensional design to ensure that the part fits where it's supposed to), so the manufacturers are unlikely to know what's adequate (apart from a bit of empirical data). When you have to design a component for a purpose (and anticipate the loading on that component for its full lifetime) it becomes a whole lot more complex. I don't know of too many fab or machine shops with FEA software, and more importantly, the knowledge on how to use it.
  • Like 1
At the other end of the scale...
I can buy a set of trailer axles, backing plates, brakes, springs and so on and build a tandem car trailer.
Get a weigh bridge docket for the tare, fill out the various "home built" forms for the VIN plate and have a registered trailer on the road.
The backing plate brackets are flame cut from 12mm mild steel plate and one welds them to the axle with no pre or post heat treatment.
Could have around 3t rolling down the road on the back of the 4X at up to 100kph.
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
