Sau Vic Motorkhana #1 - 28th Feb 2015
ssxRicho
Confirmed Entry List (entries full)
https://www.meecamsau.com/index.php?option=com_content&view=article&id=25&eventId=609&Itemid=521
At this point entries are full, thank you everyone for the interest. Sorry to those who didn't make it in, however this is a test event for us. I'm hopeful to open entries to a larger number of people next time around.
There are still a couple of spots up for grab to new members who want to get involved. So if you've signed up in the last 12 months, PM me.
As most of our members are aware, our previous Motorkhana facility (DECA Shep) was sold in 2014. The new owners of the facility altered the hire arrangements and made it impossible to insure the facility under AASA.
The committee with your support spent a good part of 2014 investigating new venues to conduct Motorkhana and entry level Motorsport events in 2015.
I'm happy to announce that we will open entires to members for our first Motorkhana of 2015 this Friday the 16th of January 2015 at 7AM. Entry details will be published on the forums, facebook, email and on our website.
In preparation for entry you should sign up for a CAMS Event Entry login (free). As this is the system we will be using to manage entries for this event.
We will be taking entries via credit/debit card only. Processed through the CAMS secure payment system.
There will only be 30 positions available!
Saturday the 28th of February
Members Entry Fee $85
Affiliated Car Clubs Entry Fee $105
Please read the suppregs and ensure you read through and understand them carefully.
http://sauvic.com.au/motorsport/entry/SAU_VIC_Motorkhana_1_SubRegs_Event_Schedule.pdf
(note this is our first CAMS template and we will improve the consistency as we move forward)
The new facility is the Foresite Training complex in North Laverton. We have to extend a thank you to the owners and operators of the site for allowing us to conduct this (and hopefully future) events.
Example of site (not setup as we will have it)
SAU VIC has been affiliated with CAMS for a number of years, which allows our member to apply for competition licenses and attend track days, hill climbs and Motorkhana events held by other clubs under CAMS insurance.
The big change for SAU VIC in 2015 is that we will be conducting events under CAMS insurance.
In previous years a AASA license would have allowed you to enter our Motorkhana events, this is no longer the case. You will need to hold at a minimum a CAMS L2NS license. This type of license will allow you to attend our and other clubs Motorkhana events only.
We would suggest that you opt to get the L2S license however, as it gives you access to attending events at track days (Sandown, Phillip Island, Winton, Calder etc).
http://docs.cams.com.au/CAMS%20Forms/Competitors/CAMS%20Level%202%20Licence.pdf
CAMS requires you to be a member of a CAMS affiliated car club (of which we are), so if you aren't a member of SAU VIC become one today.
http://sauvic.com.au/how-to-join
The schedule for the event will be forthcoming closer to the date. This being the first time using the site and running a CAMS based event, we expect there will be some bugs to iron out.
We will also be announcing shortly:
> Driver Skills and Practise Day (Sandown)
> Driver Skills and Timed Laps (Broadford)
Yours sincerely,
SAU VIC President
John Richardson
  • Like 4
so the insurance is limited by the venue, eg calder/PI refuse AASA insurance.
this venue is being run under CAMS insurance and thus they don't allow AASA licenses.
we were having trouble getting AASA to cover some of our events (one of the reasons deca died off for us)
so we have moved to CAMS so yes you need a CAMS license, but still better than no events at all.
nope but they will take insurance from dodgy brothers so long as they could get a booking.
basically in VIC it just winton and calder that will accept.
we need CAMS for all the other venues we will be hiring this year as well,
plus cams work everywhere so people much better off to have that anyhow.
Entered. God bless SAU-Vic member priority entry - gonna suck if you aren't a member, looks like this is gonna sell out fast
And as for CAMS / AASA - just get CAMS, you can use it at AASA events ... So you never have a problem with will/wont it work
  • Like 2
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
