Just thought i'd post this in case any one comes across a similar issue.
Some months back had an MV Auto shift kit fitted to my rwd C34. Everything was fine and dandy for a few months until one day i wanted to have some real fun, manual mode, wot.
Got home and noticed funny whirring sound from trans, checked fluids etc, found everything good.
Next day drove it in D seemed fine, switched to manual and revs would flare approx 500 rpm for each change, back into D and fine again.
Spoke to MV auto and they said they hadn't heard of that sort of prob before and it sounded strange and i should get it checked.
Found a local tranny bloke here in Western Suburbs and described symptoms. He said it was very strange as the symptoms should show up the other way around. If there was an issue with the trans, i.e if the pump was dropping pressure it would show up in D and manual mode should make it seem less obvious. He said it might be a TCU problem.
I decided to see if i could get it to relearn by disconnecting the battery and drain power by jumping on the brakes. After reconnecting and driving it for about 20 mins no change. Booked it in for a check up. Went to drop it off this morning and it was good again. Tranny bloke said it would've been the first thing he would have done as well.
So now back to Yee Ha and smiles. I'll keep posted if issue returns but am hoping relearn has solved problem
Cheers
https://www.sau.com.au/forums/topic/452724-weird-trans-issuesolved/
If you use a consult cable and the free software OBD scan tech, you should be able to access the auto section of the ECU. It will display the status of all the relevant sensors and solenoids. This works on a s1, I know there are some differences with the later ECUs.
That would be a good start to see what is going on. You can log the sensors as well to capture what is happening when the gears flare.
    • @Dose Pipe Sutututu I would argue that >300rwkW inevitably comes only with a raised boost threshold that makes it more likely to get beaten by the family SUV with a 95 speed auto transmission and TD torque. Ditto the traction problems when it finally does come on boost. I used to love my stock turbo. A little flex of the ankle and it made a sweet little whistle and you had torque immediately. It wasn't fast fast, but it was more likely to win the "squirt to make the gap" type races that actually matter for a street car. I think >300 rwkW requires more capacity than an RB25 can offer (again, for street driving). I have enough experience with driving 2JZs in that space to know that they are much easier to pedal around in than a 25. I keep thinking Greg did the right thing putting a V8 is his car. I can't see myself not having a turbo - but I'd really like a big engine torque curve.
    • This is kinda how I see it also. Could drill down then into sub tags.
    • Let's be honest here @GTSBoy 250kW in a GTS-t would easily get walked by my a family SUV these days. 300kW is the sweet spot, fast enough to keep up with the modern German cars (not from a stand still), fun enough and the motor still can be stock/unopened. Realistically, 400kW is a good number. It's enough to give you cold sweats, still be very street able in terms of the power band (provided you're not an idiot and go single scroll and delete VCT) and only needs a very basic rebuild (or stock if you have a NEO motor). Anything more, it starts to be stupid.
    • Deals off now apparently https://www.abc.net.au/news/2025-02-13/honda-and-nissan-say-merger-talks-called-off/104934438 Hopefully Nissan closes up soon and the family X-Trail becomes a classic too!
    • The west where I live is swarming with birds, not wrong they are bloody loud. In the meantime, do a DIY killswitch - $5 worth of things from jaycar, easy as too. The west is copping it with car theft lately, especially the big shopping centres.
