Just thought i'd post this in case any one comes across a similar issue.
Some months back had an MV Auto shift kit fitted to my rwd C34. Everything was fine and dandy for a few months until one day i wanted to have some real fun, manual mode, wot.
Got home and noticed funny whirring sound from trans, checked fluids etc, found everything good.
Next day drove it in D seemed fine, switched to manual and revs would flare approx 500 rpm for each change, back into D and fine again.
Spoke to MV auto and they said they hadn't heard of that sort of prob before and it sounded strange and i should get it checked.
Found a local tranny bloke here in Western Suburbs and described symptoms. He said it was very strange as the symptoms should show up the other way around. If there was an issue with the trans, i.e if the pump was dropping pressure it would show up in D and manual mode should make it seem less obvious. He said it might be a TCU problem.
I decided to see if i could get it to relearn by disconnecting the battery and drain power by jumping on the brakes. After reconnecting and driving it for about 20 mins no change. Booked it in for a check up. Went to drop it off this morning and it was good again. Tranny bloke said it would've been the first thing he would have done as well.
So now back to Yee Ha and smiles. I'll keep posted if issue returns but am hoping relearn has solved problem
Cheers
https://www.sau.com.au/forums/topic/452724-weird-trans-issuesolved/
If you use a consult cable and the free software OBD scan tech, you should be able to access the auto section of the ECU. It will display the status of all the relevant sensors and solenoids. This works on a s1, I know there are some differences with the later ECUs.
That would be a good start to see what is going on. You can log the sensors as well to capture what is happening when the gears flare.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
    • The log you did with ECU voltage, can you log the other things too like rpm and oil pressure? Need all that info together to compare easily
