Parts for R32,33,34 gtr. Willing to ship if required, located in 3015 Melbourne.Having trouble uploading pics, but are available. Any questions please ask. Thanks for looking.
R32 Gtr Replica Kansai strut brace $250
R33 Gtr turbos, manifolds and dump pipes, no leaks, or wheel damage $350
R34 Gtr carbon canards for front bumper $300
R33 Gtr castor arms with near new nolathane bushes $150
R33 Gtr twin turbo pipe $100
R33 Gtr exedy button clutch and lightened flywheel 15,000km $200
R33 Gtr injectors 440cc $100
R33 Gtr cams standard $150
R33 Gtr cam pulleys standard $50.
R33 Gtr intercooler, no leaks or damage $150
Price drop.
R32 Gtr Replica Kansai strut brace $150
R34 Gtr carbon canards for front bumper $200
R33 Gtr castor arms with near new nolathane bushes $100
  • 1 month later...
Added more parts and lowered prices.
R32 Gtr Replica Kansai strut brace $100
R34 Gtr carbon canards for front bumper $150
R33 Gtr castor arms with near new nolathane bushes $75
R33 Gtr twin turbo pipe $75
R33 Gtr exedy button clutch and lightened flywheel 15,000km $125
R33/34 Gtr Apexi Super Suction Kit for Z32 AFM Fitted for 750km $400
Z32 AFM x2 with connectors $250
Edited by Musashi33
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
