These were custom re-valved by Gary (Sydneykid) and are out of a winning production car. They are not from the SAU group buy.
Have moved to Racepace Tein Circuit Masters. Bought from a member on here. They stand up quite well against the Teins especially considering the big price difference between the two. At this price I believe they are great value for money.
Spring rates : 7kg/mm and 5kg/mm.
$850 + Freight if required.
Melbourne
0425 730 031
(ignore the swaybars on top)
  • Like 1
any idea how many kms on them?
They haven't been used on a road car to do daily K's. The member I bought them off probably only used them for 5-10,000km's before his car went into storage and was eventually parted out.
edit : oh and i've done about 5,000KM's on them. (including x1 Deca and x1 Haunted Hills)
What ride height did you have these at and how low do these go? Thx
I asked Racepace to set them up for handling. I haven't measured them however the lowest point of the car was a bit higher than 100mm. Most of the 32R's they have setup are almost identical height, including my current setup with the Racepace Teins. They can be lowered much more if you like for looks or even raised if required. The handling is superb.
Some photos of height:
  • 3 weeks later...
  • 3 weeks later...
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
