Get your hands on a return flow Blitz SE is the preferred choice of IC's then you won't need a angle grinder.
You will have to gently manipulate the front bar, and the front reinforcement bar.
Stock -
Then a little cutting -
I'm pretty sure theres a guide on SAU somewhere in the archives or "how to" section on this.
Difficulty is like a 3/10
  • Like 1
With the blitz return flow. Does that hook straight up to existing stock pipes? Meaning do the pipes from the IC go to where the sidemount existing pipes are?
Correct
Buy a universal fmic that can be mounted without any chopping, mount it, have piping made to suit with minimal chopping e.g a return flow and then u just need the original pipe holes made larger under the airbox. Just an idea.
Edit: buy return flow, use ur existing pipes is a great idea.
Edited by FordyR31
I have a blitz SE on a R34. You do need an angle grinder.
Blitz even include a picture of what you need to cut.. It isn't much, but if you cannot cut the REO bar then well its going to get annoying.
(Dunno about r33)
If I could do it again, I'd get a good core then make sure the piping fits with no cutting by asking a fabricator to make up the cooler pipes and brackets to fit.
Series 1 R33 with Blitz cooler using the stock pipes through the bodywork.
Small amount of front bar grinder work required, nothing dramatic. Have a mate hold the bar while you mark, cut and test try.
Suggest you double clamp all the silicon hoses, bit of a mission to get at some in the future.
Use 8mm??x ¼" drive socket to tighten them, not a screw driver.
Mount the cross over hose clamps such that you can access then from below but angled slightly to give max road clearance.
You will hit the cross over pipe on big speed bumps or poorly designed driveways and then that driver's side silicon joiner and clamps are susceptible to damage.
  • Like 2
    • Do the following first and get back to us. - Clean and verify your IACV - Verify for vacuum leaks/post MAF leaks. (Pressure test is the best and cheapest way) - Do you have a BOV with stock ecu/MAF? If so, remove it.
    • Hey all, The skyline I have is stalling when the engine is at normal operating temp.  When starting it while it is cold, it'll run just fine.  I have replaced the battery (bad cell), I have replaced the fuel pump, fuel filter and clean the MAF sensor.  Any other suggestions?
    • Thanks for all the information on this.  I tried ordering the parts from Amayama website and all 3 Solenoids are discontinued and not available.  Does anyone have any other websites to suggest that I could find the parts?   Separate issue-- I will start a new thread, but basically the vehicle is stalling when warmed up.
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
