Year: 2001
Make: Renault Sport
Model: Clio 172
Km's: 171000
Reg: March 2015
RWC: Yes
Price: $7000 (will consider trades, with up to $5k on top)
Contact: James - 0431320142
Engine and Exhaust
Renault Sport 2.0L F4R
RS Tuner Premium with Stage 1, 98 RON map
Custom intake with pod behind fog light (fog light removed, mesh installed)
Battery relocated to boot (fused, kill switch, braced, boxed, vented)
ECU relocated alongside fuse box
Standard exhaust with stainless steel, high flow cat, and high muffler (flange connections installed to easily swap between standard muffler)
Driveline
Standard JC5 5 speed
Suspension and Brakes
182 Cup shocks and springs, modified to fit 172
Powerflex camber bolts
Standard front rotors with Predator pads
Standard rear rotors and pads
Wheels and Tyres
Standard 15" alloys with Bridgestone Potenza re002 tyres (195/50r15)
Exterior and Interior
Standard Body and paint (Iceberg Silver)
LH foglight removed with black mesh over hole
Standard Interior (items currently removed to save weight: CD stacker, spare wheel/tools [battery in well], rear seats, trunk carpet. Items kept and can be easily refitted.)
Description
It is with apprehension that I’m putting my 2001 Renault Sport Clio 172 up for sale. Up until recently, this was my girlfriends’ daily driver; but as I just bought her a Megane 225, I've taken ownership of the Clio. It's is in fairly good condition for a 13 year old car. The exterior comes up really well when clean, and whilst there are a few imperfections, it still turns heads. The interior is pretty clean too... both are probably around 7/10.
Mechanical it seems to still be in great condition… the engine is strong, gearbox is smooth, suspension and brakes work perfectly, and there are no funny noises. Receipts show it has had a really good service history. When my girlfriend purchased the Clio, a bit over a year ago, we chose this one because it had obviously been well looked after, and felt nice and tight. It received 4 new rotors and pads, new rear shocks, new rear wheel bearings and new front strut tops for the RWC (12/09/13). Shortly after purchasing it we had a pedantic Renault "specialist" look over it (26/09/13). They replaced the crank pulley, both inner tie rods, a driveshaft boot, the pollen filter, and the brake fluid. They also replaced the ECU and Body Computer to fix an intermittent immobiliser fault. Just between the RWC and the follow up work, $3000 was spent on the Clio.
Since taking ownership, the Clio completed it's first track day at the 2014 OzRenaultSport Nats at Winton. I entered the car in standard form, and it performed faultlessly, and was a blast to drive. I'd like to complete some more track days now, and if the Clio does not sell in a hurry, it will likely see some more track days. I've started performing some subtle mods to help it perform on the track.
Recently (Nov '14) the car has had the following work completed: A free flowing muffler fitted, with flanges welded on to the new, and standard muffler, so as to easily change between the two (high flow cat already fitted); Custom intake with pod behind fog light; RS Tuner; Battery relocated to boot; Timing belt, water pump, etc replaced; Predator front brake pads installed and rotors skimmed; Practically new 182 cup shocks (modified to fit) and springs, plus camber bolts installed; Oil and filter changed; Parts/interior removed to reduce weight (easily re-installed). This month (November) at least $2700 has been spent on the Clio.
It has registration until mid-March 2015, and at my asking price will come with a RWC.
  • 3 weeks later...
PRICE DROP AND AD UPDATE
Year: 2001
Make: Renault Sport
Model: Clio 172
Km's: 172000
Reg: March 2015
Price: $6000 (will consider trades for Japanese sports car, Clio 3, Megane 225... with up to $8k on top)
Engine and Exhaust
-Renault Sport 2.0L F4R
-RS Tuner Premium with Stage 1, 98 RON map
-Custom intake with pod behind fog light (fog light removed, mesh installed)
-Battery relocated to boot (fused, kill switch, braced, boxed, vented)
-ECU relocated alongside fuse box
-Standard exhaust with stainless steel, high flow cat, and high muffler (flange connections installed to easily swap between standard muffler)
Driveline
-Standard JC5 5 speed
-182 Cup shocks and springs, modified to fit 172
-Powerflex camber bolts
-Standard front rotors with Predator pads
-Standard rear rotors and pads
Wheels and Tyres
-Standard 15" alloys with Bridgestone Potenza re002 tyres (195/50r15)
-Standard Body and paint (Iceberg Silver)
-LH fog light removed with black mesh over hole
-Standard Interior (items currently removed to save weight; items kept and can be easily refitted)
-Custom (removable) rear floor and carpet to cover rear battery and seat void
Issues
-Small, but deep dent in bonnet (as pictured)
-Thumb grip on steering wheel has deteriorated
-Hazard light switch faulty
-ESP light on since ECU/UCH swap. This is not an ESP model... I'm guessing the ECU/UCH came from an ESP model
-Airbag and SERV lights on since removing rear seatbelts... can be fixed with resistors
-Battery nearly due for replacement (only causes minor issues... trip meter reset, slower fob recognition)
Description
It is with apprehension that I’m putting my 2001 Renault Sport Clio 172 up for sale. Up until recently, this was my girlfriends’ daily driver; but as I just bought her a 225, I've taken ownership of the Clio. It's is in fairly good condition for a 13 year old car. The exterior comes up really well when clean, and whilst there are a few imperfections, it still turns heads. The interior is pretty clean too... both are probably around 7/10.
During November 2014 the car has had the following work completed: A free flowing muffler fitted, with flanges welded on to the new, and standard muffler, so as to easily change between the two (high flow cat already fitted); Custom intake with pod behind fog light; RS Tuner; Battery relocated to boot; Timing belt, water pump, etc replaced; Predator front brake pads installed and rotors skimmed; Practically new 182 cup shocks (modified to fit) and springs, plus camber bolts installed; Oil and filter changed; Parts/interior removed to reduce weight (easily re-installed). Since November at least $2700 has been spent on the Clio.
It has registration until mid-March 2015, and should only need a couple of tyres, and a few parts re-installed for RWC.
Custom intake, battery relocation and custom rear floor
-12 months reg just paid ($647)
-Carbone Lorraine RC 6 and steering wheel boss kit on order ($500)
-Stereo upgrade in process ($350)
-Fault lights on dash fixed
-Currently has 70kg of weight removed
  • 3 weeks later...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
