Or not. Any sensible Skyline owner who pushes the car hard will kill HICAS with fire to stop it from diddling the back wheels while trying to hold a line at 9/10ths or more.
Wtf does that even mean? Trying too hard to put too many words together.
Agreed, most likely drifting/track, not that it matters either way. Keep the hicas bar if already fitted.
  • Like 1
actually yeah you're right sorry, I forgot you sometimes speak fluent pompous-git mixed with some sort of inbred 18th-century coalminer dialect.
as per defintion
1.
affectedly grand, solemn, or self-important.
"a pompous ass who pretends he knows everything"
  • Like 1
Guest
